Results 1 to 9 of 9
Thread: squeak squeak, help me pls!
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    ok, recently my left rear "suspension" has been squeaking like a mofo!
    i cant tell, but it ALMOST sounds like the right rear side is starting to, which is scary since the left side SLOWLY got more annoying.
    its at the point now where any time i go over a non smooth section of road (i am not even talking about bumps) the damn thing creaks. i can hear it loud and clear, and it bugging the hell out of me.
    whenever i get into or out of the car it makes the noise. so basically whenever it moves up or down. as far as i can tell its not rotational at all.
    here is my setup:
    tokico blues on the back, with H&R springs....
    the front has konis, with the same springs....
    i installed these myself, and they had been fine up until this last week of squeaking.
    what can i do, and what could this be. it doesnt seem serious, its just hella annoying! help me out here guys!
    86 Honda Accord LXI HB 5-sp
    Central California
    Is the sound comming from the front or rear?
    Now I d
    bobafett's Avatar
    Longview, WA
    its coming from the rear, and not a peep from the front (so far, fingers still crossed!)
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Jim this sounds like the problem that I pm'ed you about. He told me it was the sway bar rubbing against the bushings (if i remember correctly). I thought it was the ball joint right up above the tire, so hit it with WD-40 and i actually haven't had a problem since.
    Alex
    bobafett's Avatar
    Longview, WA
    hmm, so look around the sway bar and see if its rubbing? - could this be from the springs settling and now they are rubbing since they are a tad lower?
    also check the ball joint above the tire? hmm, i will go check it out. thanks for the reply! hopefully this will fix it.
    86AccordLxi, which was causing the squeak in your case? the ball joint or the sway bar?
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Still not quite sure (haven't really checked out my car since i sprayed the WD-40, besides 1 drive), but i'm almost positive it was that joint right above the tire. I hit that thing with a lot of wd40 and i think it may have stopped squeaking, but we'll find out. I'll tell you how it is at the NW meet
    Alex
    bobafett's Avatar
    Longview, WA
    hehe good deal.
    well i sprayed that area, and it still squeaked. but that was last night and TODAY that it squeaked.. then i come home from work TONIGHT, and its done squeaking... i think the car gods are done punishing me!
    Nov 2002
    87 Accord Lx-i 4 door, 5-speed
    Las Vegas, NV
    My car has the same problem...it always seems to start doing it whenever it gets humid out, we sprayed the upper ball joint with a ton of WD-40 and it stops, I think I need new ball joints, but they look like they might be hard to change?
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    For the fronts, you need to change the whole arm. For the rear, it's also simple. Get a 2-jaw puller, it's easier that way. Probably less than 20 mins job each side.
  1. Insane front suspension squeak!!!
    By zeus in forum Classic Honda Community Chat
    Last Post: 09-07-2006, 08:06 AM
  2. Brake Squeak
    By MrBen in forum 3geez Accords
    Last Post: 02-10-2004, 02:25 PM
  3. brake squeak....
    By 89accord_lxi_coupe in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-18-2003, 09:16 AM
  4. Squeak when changing gears
    By tozza6 in forum 3geez Accords
    Last Post: 06-15-2003, 07:16 PM
  5. Squeak in right upper control arm
    By b&t88accordlx in forum 3geez Accords
    Last Post: 05-12-2003, 10:19 PM
