Results 1 to 8 of 8
Thread: cold start prob
    1989 Accord LX
    cold start prob
    well, my car is haveing a hard time starting when it is cold out now. I have been pluggin in the block heater regularly.
    Every morning I go out and give it two shots of gas and start it. It starts fine and everthing is dandy for about 10-20 seconds, this is when the rpms drop and the car dies. If I try giveing it gas as the rpms drop it dies faster. At this point, it doesn't matter if I pump the gas or not. The car will start only twice more and die immediatly after starting. Further attempts at starting the car ar futile. I get out scrape my windows, sit back in the car for a minute, don't touch the gas and the car usually starts without incident. I can then drive away with no problems. What's going on here?
    89 Accord LX: Fram air Filter, Flipped lid, Bosch Platnum plugs, NGK 8mm wires, Accel coil (8140).
    Things to come: Front and rear sway bars off SEi, Front and rear disc brakes off SEi, struts and springs, 4-2-1 manifold, 2.25" custom exaust, 16" rims (ROTA circit 8) with 205/45/R16 rubber (Falkon), clear taillights, new paint (this summer), custom cold air intake with box, oh ya, and fancy blue vacum lines
    89 Accord LX Coupe
    Vernon BC CANADA
    try turning the key on a few times off and on first and then hit the gas just a little bit....not all the way...only half way.
    then try start it....
    does it idle like it should after you do get it started???....does the fast idle kick in??
    id check all your vacuums over and see if the choke is working properly...
    BEn
    1989 Accord LX
    fast idle kicks in, idles like it should until it dies. Vacuum checks fine and the choke is closeing all the way.
    3Geez Veteran 87AccordsterLx's Avatar
    Nov 2001
    1991 Supra Turbo W/ 12k Miles
    Wyotech @ Laramie, WY
    what does it take to keep it running at a normal idle...?? Can you get it to idle right once it warms up... ?
    ~Nathan~
    "There's always something waiting at the end of the road. If you are not willing to see what it is, you probably shouldn't be out there in the first place."
    ~StOcK PiCs~
    1989 Accord LX
    Ontario Canada
    I'm having similar problem with my carbed 89. Starts fine, runs normal on chock for 5 seconds then starts sputtering obsenities. In my case I think the choke unloader is not working. I believe the chock plate should open just a tad right after the engine starts. With the air cleaner off I could see this was not going to happen. Any body else have an idea how to get this system working. Everything is lubed up and loose. It looks like electrical choke. Do I need to drill out rivets and check inside?
    Carobotics,
    After your engine dies, get somone to open the choke a bit when you restart(assuming you're carbed)
    Frank
    89 Accord LX / Carb
    89 Accord LX Coupe
    Vernon BC CANADA
    is your heater hose hooked up and workig...
    theres a hose that runs from the header to the air cleaner and theres a little flap inside that should close off the air flow from the cold air and use the warm air from the header...
    if it isnt working the carb will freeze up when its freezing out..
    BEn
    1989 Accord LX
    well, that brings me to another question, actually 2. Were does that piece of crap tinfoil tube hook up to? I took out the cat. converter, so I hope it didn't hook up there. And how do I test the choke unloader.
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    "Were does that piece of crap tinfoil tube hook up to?"
    Around the headers, as u can see!
    "And how do I test the choke unloader."
    Look at the gap between choke flap and bore, ~1/8" once the engine was started.
    But i think Dutchboy had a point there with carb icing.. U may also have a look at ur EFE heater, that insulator at the carb base (if u got one)!
  1. cold start car stalls like someone took the key out?
    By Burn1nRubb3r in forum 3geez Accords
    Last Post: 10-24-2011, 11:42 AM
  2. another cold start issue
    By valleyweb in forum 3geez Accords
    Last Post: 02-13-2007, 12:33 PM
  3. cold start
    By Fuzy Navel in forum EFI Tech
    Last Post: 11-30-2006, 03:49 PM
  4. Cold Start resolved!!!!!!
    By Jasonf860 in forum Carburetor Tech
    Last Post: 10-28-2006, 06:40 AM
  5. cold start problem
    By carobotics in forum Carburetor Tech
    Last Post: 11-05-2002, 09:02 AM
