Anyone have any tricks they used to get the flywheel unbolted !
Me and a friend tried gettin it out, but the bolts would not move.
I had some good leverage but no go, and also was useing penetrating lube. any one have any ideas ?
thanx in advance
thanx in advance
89 efi conversion
17" katana, lude arms, full 2" exhaust/hollowed cat, Ractive intake, centerforce dual friction, msd coil/wires
how did you keep the flywheel from turning ! ?
MIKE
Good luck.
I tricked my landlord into lending me his impact wrench so I could get my car put back together and out of his driveway. It still took 15-30 seconds on each bolt at the maximum setting.
I'm curious too, how are you holding the flywheel? I used a screwdriver in the ring gear to tighten the bolts back on, but that wouldn't have been enough for me to get them off.
Mike
buy holding the other side thru the wheel well with another ratchet. Take a look you will see the hole going thru to the bottom pulley bolt
89 efi conversion
I was just reading the haynes manual and the only special tools would be a 12 point socet.
Ryan
yeah you will have to use impact wrench. i just replaced flywheel and clutch assembly on my friends 4runner truck. the bitch will be when you gonna tighten the bolts, on my buddies truck the flywheel must be tighten at 80lb. yeah,that was two people job for sure. i had to make sure the flywheel doesn't turn and he was doing tightening.
Thanks for the input ! I'm gonna borrow a compressor and impact gun from a friend of friend on wednesday. So this weekend should get her together ... hopefully
89 efi conversion
