So, I removed my head to replace a blown head gasket and car ran pristine! Now after reassembling, Cylinder 4 is now missing. Plug wires, Dizzy Cap & Rotor, Spark Plugs all brand new and sparking perfectly. Pull plug wire off cylinder 4 and no changes in engine load, or idling. Still the same consistent miss. Compression test at 171.
What else can it be other than the Fuel Injector?
My problem is IDK what the injectors resistance is supposed to be, nor how exactly to tell if the injector pigtail has power when firing.
Any ideas or suggestions are welcome!
Sent from my SPH-M820-BST using Tapatalk 2
