Anybody ever tried taking that thing out or had successfully taken it out before?
"Please don't hesitate to use full throttle."
Do you mean the tie rod end or he tie rod itself? Why do you want to remove yours?
Mike
probably to hit you for asking it. hehehehe, just kidding. Is it bent or something man? u gotta follow the instructions and mark the stock lock nut (or whatever its called) positions before loosening them. Its a dirty hard long work. Have fun.![]()
yes just like smufguy said ! you mark it so you won't mess alignment when installing again !
MIKE
Thanks for all your replies. The reason why I'm thinking about taking the entire rod out is because I am suspecting something to be wrong with it. It squeaks everytime I steer and it's just getting worse. Oh, about the marking of the nut, I'm cool with that since I'm going to get an alignment after replacing the rod anyways.
i don't think it's the problem !? do you have enough PS fluid in the tank ?
MIKE
I do. I was thinking of spraying some WD-40 on it.Originally posted by ACCORD EX
MIKE
! but this tierod already get's lubed when you steer ! i am not sure if i am right ! but isn't the steering road the thing that's connected to the rack and covered with a boot !
MIKE
