Results 1 to 11 of 11
Thread: Grinding Gears
    LX User 89LXiCoupe's Avatar
    1989 LX-i Coupe
    California
    Grinding Gears
    I don't really know what's the problem because after replacing the clutch, it still grinds from gear 1 to 2 if I go any faster than 15 mph. I can't launch my car anymore all because of that. It shifts, but grinds and I don't want to grind it like that. Does anyone know what could possibly be the problem?
    "Please don't hesitate to use full throttle."
    Scorpion88LX's Avatar
    Oct 2002
    88lx,5speed
    winston-salem, North Carolina student at Oklahoma State
    play with the clutch cable adjust nut, try and get the clutch point off the floor
    Ryan
    1989 LX-i Coupe
    California
    The cable adjust nut had been done. I'm not too sure what you mean by getting the clutch point off the floor.
    SEi User
    Jul 2002
    '89 Accord LXi Coupe w/Sunroof
    Santa Clarita, CA
    he means that the clutch cable might not be pulling the realease arm up far enough. and that your clutch pedal when its on the floor is semi disengaging the clutch. you clutch should be fully disengaged when it is on the floor and about a inch up it should start to grab. maybe you clutch point is under that 1 inch and its not fully disengaged = grinding.
    ACT Stage 1, Short Ram Intake & 2.25 Dynomax custom catback w/4inch carbon fiber tip. Thats it for now.
    Putting the paint back on after
    SOMEONE STOLE MY PAINT!!!!!
    Oct 2002
    88lx,5speed
    exactly
    Ryan
    1989 LX-i Coupe
    California
    Oh, so that's what he meant. But still, if this was to happen, shouldn't all my gears grind and not just the second gear?
    SEi User
    Jul 2002
    Santa Clarita, CA
    have you ever noticed that when your in 4th and 5th that your car doesnt jerk even if your gas is on full throttle. vyour lower gears dont need as much engagement. you can actually revmatch each gear. but i would not recommend it cuz you will fuck up your tranny. so the asnwer is no. im just tryin to get you thinking.
    88 Lxi/ 5spd
    Tennessee
    1. check oil 2. get somebody to check first and second gear....the synchros or something might be worn ( i really don't no much about that)
    In the end...it doesn't even matter.
    88 Lxi, 5spd swap w/ Aasco 8lb flywheel/Cai,AccelCoil,NologyWires,SilverstoneSparks/DC421,ColtCam,Remachined Head&Tb...NitrousWorks 40shot
    SEi User
    Jul 2002
    Santa Clarita, CA
    oh yeah i forgot all about that. the synchros might be worn. if so a tranny place will be able to tell you if they are. if they are then you need to get a new tranny. or used or rebult one.
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Did you replaced the clutch yourself and when? How about warranty if you brought it to the shop? Just go in and start bitching.
    1989 LX-i Coupe
    California
    Well, me and my brother did it ourselves just this past June. He knows his stuff and I do trust him working on the car. Let's see, he put the motor in for me almost a year ago and did all that stuff while I was away for school and not only that, but he's worked with many trannies before. He even rebuilt the motor in his Legend. See, his belief is that if he knows that he could do it, then he won't rely on someone else to do it for him. I just had to ask about my gear grinding, but he said he'll find a weekend off to check it out for me.
  1. 3rd gear grinding
    By 88accordlxcarb in forum 3geez Accords
    Last Post: 12-03-2006, 02:28 PM
  2. grinding gears
    By hootymo in forum 3geez Accords
    Last Post: 01-31-2005, 01:24 PM
  3. Grinding
    By 88' Accord Ltd in forum 3geez Accords
    Last Post: 10-26-2002, 05:53 AM
  4. grinding
    By Bullfrog in forum 3geez Accords
    Last Post: 09-20-2002, 10:32 AM
  5. grinding
    By Bullfrog in forum Classic Honda Community Chat
    Last Post: 09-19-2002, 03:41 PM
