Results 1 to 25 of 49
Thread: 1983 Brake booster failure?
    LX User charliefowle03's Avatar
    Mar 2012
    1983 Honda Accord automatic EK1
    Columbus Ohio
    Have been slowly hearing a hiss noise coming out of the brake pedal region for the past couple of days and noticing a pressure drop in my pedal. The only other symptoms i can report are the pedal is rock hard right now, the rpm rise as i press the brake pedal in, the hissing noise is louder than ever. There also appears to be some major rust on the booset from both inside the engine and down by the pedal lever. any ideas??
    Uploaded with ImageShack.us
    Mar 2012
    Columbus Ohio
    Re: 1983 Brake booster failure?
    the freakin hair is fantastic. FTW
    Sounds like a bad booster to me.
    Mar 2012
    Columbus Ohio
    My question is that if i have such a significant vaccum loss in my motor that my power brakes dont operate , how is it that my car is is still able to start just fine and run ok with out any noticable fluctuations in the rpms?
    Also, is the power steering system in any way connected to the braking system? Because i feel a slight increase in pressure in the turning the wheel, especially to the right? Or is this just the vaccum leak affecting the rpm which then leads to lower pressure in my P.S. system
    as well?
    um from looking at those pics you need a brake booster lol
    Mar 2012
    Columbus Ohio
    Ha, and a vaccum. Now my question is to how do these typically fail. Just age? Does it nessecarily mean i need a new maaster cylinder as well" Or is it juast nice to replace this at the same time?
    Seems like your master cylinder was leaking into the booster causing it to rust and leak. Pull your master and check if its wet too.
    best just to do both, you will need to reset the new booster pushrod length anyway, so you can do it out of the car, best one is to look for a new beck arnley brand on egay, they are closest to factory, factory electrical plug on the resevoir cap and everything
    Mar 2012
    Columbus Ohio
    There does appear to be wuite a bit of rust and some fluid leaking under the resivoir onto the booster. Where does the leak most commonly occur. I mean is it an o ring that just fails inside the cylinder or is there like a gasket that mounts up againgdt the booster between the master cylinder. I would love to salvage if possible. SO broke
    Pull out your manual and look at the blow up diagrams. It will show you how to overhaul the parts yourself. It looks like Rock Auto has a kit to rebuild the master cylinder. Of course, it's not appreciably cheaper than a new MC and if your old one has a lot of scoring on the internals, you'll be buying the new one anyway. You'll be hard pressed to find a rebuild kit for the booster.
    Because we're talking about your brakes here, you might want to belly up and buy the new parts. If you're in a situation of having to choose between groceries and brakes, then it's time for a little junkyard surfing. Brake boosters don't go bad all that often, so your chances of finding a working one are good. If you decide to try a junkyard master cylinder, be sure to get the warranty and be prepared to take it back a dozen times before finding a good one. Then be prepared for the good one to poop out soon.
    his isnt even a good core, look at the picture of where the pushrod goes in, the rust has caused it to break, it's gone
    Mar 2012
    Columbus Ohio
    I so dont get when you guys all talk about theses 2g in the junkyard. All these junkyards up here rock 90's and up. your lucky to find some 86-up.But yeah your right snooz, I need to fork the cash out. or chances could be that im a goner. ha
    Good news is anything from 80-00+ Hondas with the same diameter booster and master cylinder size would fit with minor alteration with your brake lines, some even fit without any modification at all.
    Look for something with the same diameter with your old booster and same master cylinder size from a 90+ Honda.
    Mar 2012
    Columbus Ohio
    Great information Hazwan! I wentt ahead and forked out the cash fora new booster and master from advanced auto-bone. I figured now would be a good time to use my 50 off onlone ship coupon. SO expecting mid next week to arrive. as for now i have anothe picture thread on the way. Wait till u see this randomness...
    Yay pics! Moar pics!
    Mar 2012
    Columbus Ohio
    Moaar to come....later this week hopefully. Parts are being shipped
    Mar 2012
    Columbus Ohio
    ....I still am confused to how the motor still manages run as if there is no vaccum leak. I mean I can't tell the difference but I certainly can hear the hiss. Can anyone explain this. Because exactly what Haz was stating the diaphragm has been contaminated and eating up by the leaking brake fluid from the master cylinder. It has been leaking into the booster for who knows how long never really could tell if I was leaking fluid. I did some brake line repairs a couple months back and was leaking a huge amount (topped off every week). But now since being aware of the obvious situation, I do not see a noticeable amount of fluid leaking . I mean I'm sure there is but it must be so slow. Like this has pro ally been going on for years and finally with the weather change/ carb swap it just took the poop.
    Why is my car not significantly taking a hit from the vaccum leak?
    Maybe the leak is small enough not to be noticeable. I had hissing booster back then too and I can't notice a thing except for my poor gas mileage. Engine runs as smooth as it can get though.
    Remember to post more pics
    Mar 2012
    Columbus Ohio
    I think your right Haz. i feel that it has been leaking for awhile now. Im glad it was slow rather than immediate though. I could have ended up in a different place than i am now :0 Like the trees!
    Mar 2012
    Columbus Ohio
    Hi guys.Update!
    I will be posting tons of pics of this, really boring but critical repair. Crazy mad JDM pics coming your way...
    Mar 2012
    Columbus Ohio
    So these are the pictures i took as I went about the repair. All went well with the replacement. No fitment issues whatsoever. God it sure does feel good to have power brakes back again! The only issue now is that after bleeding the brakes, I was upset...and terrified, to discover that my front calipers are seized, or atleast partially seized up. I am getting serious vibration from the brake pedal as well as into the steering wheel. I notcied that they were going just after the next day of driving that the lug nuts were scorching hot and the wheels reeked of burning brake pads. Then caught onto the brake pedal having inconsistent distances when depressed. sometiimes it took very little to stop the car, others times all the way to the floor. Im going to tackle this job this weekend before i again take the risk of killing myslef of someone else on the road. Looking at some remanufactured calipers on ebay for roughly 50$ each. Not sure if both are seized up but going to just do both to be safe. Sureably in one is failing the other is soon to come.
    Also picked up a Spectra radiator from O'rielys this morning due to the fact that mine has slowly been leaking and noticed my temp gauge was reading inconsitent as well Right now it reads way under o.t. Few days ago it was near overheating. I know where the leak is and i think the inaccurate reading are coming from this ahole allowing air to enter the system... any who this will be another thread most likely with fun pictures to support!!
    I will do my best to post them in an orderly fashion as i went from start to finish.
    Mar 2012
    Columbus Ohio
    UNPACKAGING!!!
    Uploaded with ImageShack.com
    Mar 2012
    Columbus Ohio
    Mar 2012
    Columbus Ohio
    First step was to remove the lines from the M.S, then go about removing the two nuts that held it to the booster. I found it easiest to use a swivel adapter to get into the lower nut.
    Yummm corrosion. Its obvious where the fluid was straveling....
    Mar 2012
    Columbus Ohio
    A few more pictures of the damage that had been done from the leak. I assume the Master cylinder had been leaking for awhile and slowly running down into the booster. It was just a slow decaying process.
    Some extra picys of the new webbyy
  1. Wet Brake Booster
    By bushbean in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-12-2009, 05:33 PM
  2. Brake hose failure
    By martik in forum 3geez Accords
    Last Post: 07-21-2003, 08:54 AM
  3. Brake booster...
    By ahbeyra in forum Carburetor Tech
    Last Post: 07-19-2003, 05:05 AM
  4. brake booster
    By 1987HondaAccord in forum 3geez Accords
    Last Post: 04-26-2003, 02:08 PM
  5. Brake Lamp failure sensor question?
    By toaster13 in forum 3geez Accords
    Last Post: 04-13-2003, 12:43 PM
