Page 2 of 2 FirstFirst 12
Results 26 to 49 of 49
Thread: 1983 Brake booster failure?
    LX User charliefowle03's Avatar
    Mar 2012
    1983 Honda Accord automatic EK1
    Columbus Ohio
    Re: 1983 Brake booster failure?
    The brake pedal nut had to be adjuster slightly. It was not far back enough, so my brake light switch was left on a closed circuit. (tail lights were staying on when brake pedal wasnt engaged.) That required a little tweaking.
    Also a note that agaiin the swivel adapter prved to be a blessing for getting the top nut of the booster bolt that was under the pedal inside the vehicle. There are a total of 4 and 2 of them took about 20 minutes haha
    Again. rusty buckets
    Uploaded with ImageShack.com
    Mar 2012
    Columbus Ohio
    Mad JDM honda matching paint on that booster baby!
    Mar 2012
    Columbus Ohio
    The resivoir did not come with the new cylinder, sop i just cleaned the original and swapped. Definately had some contimination going on.
    [URL=http://imageshack.com/i/f1csggj/]
    Mar 2012
    Columbus Ohio
    [URL=http://imageshack.com/i/0o2wrwj/]
    Nice kitty!
    Looking good man. You know, you can remove that whole Air Suction setup from the top of your intake manifold. Just cut the tube off of your exhaust manifold and crimp it shut with some pliers and then you can take all that off.
    Mar 2012
    Columbus Ohio
    i was curious to how i should approach that. i definately think its hidious i may try to find some kind plud to put in the exhaust some threaded piece. thank you for the tip brother. i wa pictures to get an idea.
  8. #33
    Or if you can cut a little round piece of metal the size of that bung, I bet an exhaust shop would weld the bung closed on the end of that tube for you for a couple of bucks.
  9. #34
    Mar 2012
    Columbus Ohio
    E=2ndGenGuy;1127887]Or if you can cut a little round piece of metal the size of that bung, I bet an exhaust shop would weld the bung closed on the end of that tube for you for a couple of bucks.[/QUOTE]
    Thats pro ally a route I can go. Same thing pro ally for the egr too huh? I don't like seeing the hideous thing!
  10. #35
    Is that how they mounted the A/C compressors on the '83s? Far out.
    Before spending a lot of money on new calipers, check your caliper guide pins. If they are not lubed properly or simply chewed up, they can cause a lot of problems. You can probably replace both with dealer parts for less than the cost of one new caliper.
  11. #36
    Mar 2012
    Columbus Ohio
    Wow! Thank you. This will give me something to do this evening. I have a feeling the rotor(s) are warped though for the duration that they seized up. Its really strange. Its like some days the brakes feel really touch other day normal. I'm getting the vibration today in the brake pedal and the steering wheel. I think worst case scenario I will replace calipers and rotors. But at leat the rotors I feel are goners.
    This doesn't feel like coincidence. After replacing the m.s. and b.b I have been getting these issues? Any reason why?
  12. #37
    Check the booster pushrod make sure it's not actually pressing the brake when it's not. Heres how I check mine since mine isn't stock and factory measurement mean nothing to me: I would jack the front or rear wheel and see if it's dragging then I would undo the pushrod nut a few turns and check the wheels again.
    Yeah Hazwan is right there, but you could also have gotten one of the calipers stuck when you were doing the bleeding. Everything always seems to work great until you dislodge some crap that gets the caliper stuck. But also like Snooz said people do brake jobs and often neglect to clean and lube the slider pins or any other moving parts.
  14. #39
    you need to adjust the free play properly with a new booster, or the brakes will gradually start to lock over time
  15. #40
    Mar 2012
    Columbus Ohio
    Wow OK. I did have to extend the bolt to get the brake light switch to be disengaged (brake light off) should I just adjust the but on the booster by the pedal back off? How do you mean it starts to lock up after a while?
  16. #41
    Quote Originally Posted by charliefowle03 View Post
    this has nothing to do with the brake light switch, thats a separate adjustment, if there isnt enough free play between the pedal arm and the booster the booster will never fully release and over time will apply gradually more pressure to the master cylinder, this is a common issue when changing boosters
  17. #42
  18. #43
    Mar 2012
    Columbus Ohio
  19. #44
    Mar 2012
    Columbus Ohio
  20. #45
    Pushrod clearance look fine to me but you said passenger side caliper is fine so its probably your caliper or the brake hose on the driver's side. How old are they? I'd replace them all if they're hardened up. As for the caliper You can either try rebuilding them or get a reman unit.
    I had the same issue with seized caliper that it actually smoking. Replacing the O-ring on the piston did the trick. I'd fix that asap before it would start ruining everything else from the heat! It can't be good for your bearing grease thats for sure
    Having your throttle cable kinked like that will make the throttle sticky. That's probably your idle issue. If you don't get it fixed, however, it could cause a crash.
    The only way to diagnose your brakes is to pull the wheel and see what's going on.
  22. #47
    Mar 2012
    Columbus Ohio
    It is nessecarily restricting the cable from retracting but when I'm at 65mph and I let off the gas it will actually downshift and the Rpms will rise. About 250rpm. But I will definitely read the PDF. Thank you
    As for the brakes its becoming intermittent. Once warmed up the sensitivity varies. The vibrations will come in after 20 minutes of driving. Then I feel theb brakes locking up. It warped the driver side rotor and brake Lin appears to be fine. Um going to order some new calipers and rotors this week.
  23. #48
    Mar 2012
    Columbus Ohio
    Ordered new Beck/Arnley Calipers, Beck/Arnley Rotors,and som eeconomy pads from RockAuto.com today....$101 shipped. used a 5% off coupon in the appearance thread on the home page...Noice. more pics to come...3-4 business days from now
  24. #49
    Mar 2012
    Columbus Ohio
    still waiting on the delivery.. Since its a holiday, most likely will get the goods tomorrow. Moar to come!!
  1. Wet Brake Booster
    By bushbean in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-12-2009, 05:33 PM
  2. Brake hose failure
    By martik in forum 3geez Accords
    Last Post: 07-21-2003, 08:54 AM
  3. Brake booster...
    By ahbeyra in forum Carburetor Tech
    Last Post: 07-19-2003, 05:05 AM
  4. brake booster
    By 1987HondaAccord in forum 3geez Accords
    Last Post: 04-26-2003, 02:08 PM
  5. Brake Lamp failure sensor question?
    By toaster13 in forum 3geez Accords
    Last Post: 04-13-2003, 12:43 PM
