Results 1 to 9 of 9
Thread: Problems Developing !!!! :(
    SEi User gr3k0sLaV's Avatar
    Feb 2002
    1998 VT Commodore 50th Anniversary Edition
    Geelong, Australia
    Angry Problems Developing !!!! :(
    Ok a couple of problems have just sparked up first started nearly week ago, when I'd be leaving work, usually around 1am, and i'd be getting alternator whine on my speakers, something i've never heard before.....it'll eventually go away once the car warms up, would I be wrong in saying the alternator is going?
    Second, tonight im driving, just take my foot off the accelerator and notice the Revs are going up and down, strangely, this seemed to have stopped and not happened since but for it to happen in the first place is strange enough to warrant c oncern,
    also just for the record my car is EFI.
    -Cheers
    Cocaine's A Helluva Drug! - Rick James
    I really fracked things up for you Bill - Colonel Tigh
    Girl we couldn't get much Higher! - Light My Fire
    carotman's Avatar
    Montreal South Shore
    When the revs go up and down, do you only see the tach acting strangely or can you FEEL the engine going up and down in revs?
    Feb 2002
    Geelong, Australia
    i could hear the engine, as well as seeing the tach, and could feel the far pulling strangely. It all ceased when I put the food on the accel and hasn't done it since.
    10/Honda/Ridgeline
    NJ
    u could have had a bad or sticky throttle linkage on the TB. i noticed that when i fired my car up after the conversion and noticed my car would like bog, like rev up and down. it was the sticky throttle spring. I greased it up and its now smoother. i also used carb cleaner to clean the inside of the TB where the flap rests. THe carbon deposits actually make the flap stick on the inside. I used a toothbrush and brushed it and wiped it off. and its free moving now.
    My carb used to rev up and down on neutral or when just idling. But after efi, it does not happen anymore
    Oct 2002
    1987 accord lx
    Chicago
    If your revs are going up and down like that, you should check to make sure that your coolant level is up to max in your radiator. I've noticed on 80's Hondas (including ludes and civics) with EFI, that when the coolant level is low and one of the coolant temp sensors can't get an accurate reading, the revs bounce up and down while the ECU is seeking to find the proper RPM for the coolant temp at idle.
    It could be something else, but I'd check that first because it's simple.
    I could see it happening now as it's getting cooler.
    I didn't notice where you live, but if it's somewhere that gets freezing temps, make sure that your coolant is safe to -30degrees, and add the proper proportion of anti-freeze & water to get it to max if it isn't already.
    Oct 2002
    1987 accord lx
    Chicago
    Shit, you're in Australia. So it's not getting cold now.
    Well, check your coolant anyway, and then check to see if your throttle linkage is sticking.
    Feb 2002
    Geelong, Australia
    Yer ill check that this weekend, well summer is coming, but it's still kinda chilly some nights.
    Here where I live, we have four seasons in one day.
    2000 Audi S4 Twin Turbo/ 2007 Honda Fit Sport/ 2010 Ford Flex Limited
    Temecula, CA
    If your reves go up at down, either your MAP sensor is going bad, or you have a vacuum leak..
    1-11-2014 Dyno Day
    587 - AWHP
    454.6 -TQ
    http://youtu.be/TqCtTbjQqFg
    www.tvme.info
    Feb 2002
    Geelong, Australia
    just strange, thanks for all that.
    Im going to start poking around this weekend, are new map sensors cheap?
    just strange the alternator problem happens at night only, until the car warms up...
  1. idling problems, starting problems...
    By AccordDX86 in forum 3geez Accords
    Last Post: 10-13-2005, 10:17 AM
  2. Ecu problems
    By casey in forum EFI Tech
    Last Post: 02-22-2005, 08:11 PM
  3. problems after problems, peep this shit
    By mugenprelude86 in forum 3geez Accords
    Last Post: 08-06-2003, 11:31 AM
  4. problems
    By Morpheus in forum Classic Honda Community Chat
    Last Post: 01-30-2003, 04:28 PM
