Results 1 to 18 of 18
Thread: how much power out of A20A ?
    Oct 2002
    1987 Honda Acoord Lxi HB
    Knoxville,TN
    Even thow I'm putting most of my money in my 2002 Protege5 I would still like to filter some down to my '87 lx-i. It is apparent to me that a swap is too costly and too time consuming so I would like to build up my A20A to it's fullest without NOS. What kind of power can I expect from a A20A ? Who has the highest HP A20A on this board and how much HP you running ?
    Justanothermike's Avatar
    88 LX-i coupe 91 LX coupe
    CA, San Francisco
    160++
    Jul 2002
    88 Accord (Australian Model Si)
    GoldCoast, Australia
    Stock sucks!
    10/Honda/Ridgeline
    NJ
    Juan was running a 240hp with NOS set up. ANd Justin is running a turbo and i dont know how much he got. If u got a 86-87 lxi, which u do u got a draw back on two things even in stock.
    1. Intake manifold
    2. Compression
    The compression on a 88-89 lxi was 9.3:1 and the intake manifold was a two stage. Get a 88-89 manifold and ur gainng around 5 hp the least.
    and other mods are ur freedom :d let ur mind loose on it.
    accord HB ( metallic green)
    B.C Chilliwack
    don't you have the 87 smuf ?
    89 efi conversion
    17" katana, lude arms, full 2" exhaust/hollowed cat, Ractive intake, centerforce dual friction, msd coil/wires
    Oct 2002
    Knoxville,TN
    smufguy, so your saying I can put a '88,'89 intake manifold on my '87 ? is it a dirrect fit ? what about the exaust manifold, leave the same ?
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    just leave it... or get a header and a cam and then port and polish the head... then get some 10.5:1 pistons and then u will be set
    Travis
    2.0Si User Neuspeed87lx's Avatar
    Jul 2001
    96 Civic (Turbo lsvtec) /87 accord lx/95 civic dx
    Agawam, Mass
    just saw a turbo 3g (a20a3) hatch over the weekend...dyno'd at 325 hp
    Jay
    1988starter
    Guest
    1. Intake manifold
    2. Compression
    Juan also has a b16a instead of his old a20
    10/Honda/Ridgeline
    NJ
    oh yeah, thats true. Forgot that starter.
    no green, mine is a 89.
    lil, the intake manifold is a direct bolt on. if u use the exhaust manifold, u gotta use a different emission control (different vaccum box and ECU) so u will be better off with getting an aftermarket header.
    SEi User toastyghost's Avatar
    Mar 2002
    a 93 z34 that's getting parted out, an 86 accord lx that now lives in a j/y, and a 90 camry le that the state no longer allows me to drive. soon to be replaced with an aprilia rs50 or a derbi gpr.
    Harrisonburg VA
    b-series performance manifolds fit w/ some drilling. higher cost, and more prep for installation, but much better performance and room to expand since the aftermarket is better.
    ~<+045+ygH05+>~
    LXi User 1989se-i's Avatar
    89 Accord SE-i Coupe
    Jokelahoma
    Has anyone here put on the BSeries manifold?
    Performance Modz: Short Ram Air Intake, Custom Exhaust w/o Cat & Resonator, Cherry Bomb Turbo Muffler, Accel Coil, Removed AC
    Other Modz: Clear Blinkers, Purple Calipers, Accord Emblem On Dash, Winking Headlights
    Oct 2000
    '88 Accord LX-i
    Connecticut
    It all depends on how much $$ you want to spend.
    '88 LX-i Coupe --- LS/Vtec
    DX User kraftaroni's Avatar
    Oct 2000
    87 lxi, DC header, ported and cc'd head, lightened valves, bluprinted engine, shot peened rods, ross pistons, custom intake, 2.5 exhaust, isky cam
    Torrance
    I have the jdm manifold. It made a big difference in power but I cut it in half ported it and welded it back together. I also have an rc throttle body and injectors that made a little difference also!
    89 coupe/ 06 TL 6spd
    Vancity
    ya i was thinkin about playin around and building up my a20 aswell..
    if you go all out...
    you could be in the neighbourhood of 160-180HP
    R.I.P Spoon Se-i 01/17/04
    Jul 2001
    Agawam, Mass
    if you go all out you could be well over 300 hp
    Jay
    Vancity
    ya.. but i'm talkin minus the turbo and NOS..
    no scheating involved..
    just straight engine...
    no turbo or nothin
    NORTH BAY ONTARIO
    160 n/a sounds good...
    and i need a resource for 10:1 pistons...
    Travis
  1. A20A to H22 Possible?
    By SOHC in forum 3geez Accords
    Last Post: 09-04-2009, 01:00 PM
  2. What is this??? A20A
    By Demon1024 in forum 3geez Accords
    Last Post: 07-20-2008, 10:21 AM
  3. A20a ? Jdm?
    Last Post: 02-01-2008, 02:39 AM
  4. Replies: 4
    Last Post: 10-21-2003, 12:58 PM
  5. a20a?
    By Immeraufdemhund in forum General Engine Swaps
    Last Post: 09-22-2002, 10:38 PM
