Results 1 to 13 of 13
Thread: can't get gas to engine HELP!!
    88 Accord lx
    Orlando
    Angry can't get gas to engine HELP!!
    lets see from about 1.5rpm's to 3.5rmp's i my car sputters like it's running out of gas or something. after 3.5rpm's it runs fine. Any ideas. its an 88lx model.
    thanks,
    Bo
    LXi User Nospeed's Avatar
    Oct 2002
    87 busted ass hatch
    Salem, OR
    did you check the fuel lines, and the fuel filter??
    - Justin
    2.0Si User Neuspeed87lx's Avatar
    Jul 2001
    96 Civic (Turbo lsvtec) /87 accord lx/95 civic dx
    Agawam, Mass
    make sure you check both fuel filters..the one near the gas tank and the one in your engine bay
    Jay
    Oct 2001
    87 Accord EX , 5spd , Manual
    clean the carb and see if the choke operates fine !
    MIKE
    adjust the air/fuel mixture screw.
    88 LX Action
    Podunk, Alabama
    try running the car, and having someone put gas straight in the carb. if it runs perfect than something is wrong with fuel filters, pump or lines. if it still sucks than play with the carb some, and clean it out.
    real 3geez http://www.3g-generation.com
    i sold the honda. now working on a car with little bit more potential, an 88 supra. i still stop by occasionally.
    Oct 2001
    does it idle ok ! if you meant that it kinda hesitates when you press gas ! so i am with shepherd79 ! A/F mixture screw !
    MIKE
    88 Accord lx
    Orlando
    it idles fine. it is just when i push the gas, and only when i'm in gear. someone told me it could be a vacume hose. anyone know about that? will a diagnostics check help?
    Bo
    88 LX Action
    Podunk, Alabama
    vaccum leak would be bad at idle.
    88 Accord lx
    Orlando
    where is the a/f screw located???
    Oct 2001
    check the faqs there are 2 lns up there about carbs !
    MIKE
    a pile of lawn ornaments
    Newtown, CT
    i had the same trouble. Esp. when trying to go uphill. Start by replacing the fuel filters. It's only like $10 total for them, and even if they were not the culprit, it would'nt hurt to change them anyway. Then just go from there.
    Let us know how it all works out.
    -Mark D.
    88 Accord lx
    Orlando
    ok i just changed the fuel filters but i haven't driven it yet. i'll let you know how it goes later onl.
  1. Replies: 14
    Last Post: 03-12-2010, 06:20 AM
  2. Found a B20A1 engine in engine-test stand
    Last Post: 07-16-2005, 07:54 PM
  3. need pictures of engine bay to help me fix my problem with engine swap
    By jerky_lxi in forum Interior & Exterior Care
    Last Post: 06-06-2003, 08:43 PM
  4. Replies: 11
    Last Post: 06-19-2002, 02:49 PM
