Results 1 to 5 of 5
Thread: Distributor
    Oct 2002
    89 carbed LX sedan
    Jax, FL
    Distributor
    Hey,
    Anyone know if it's possible to rebuild a distributor? Are there any kits/parts etc. availble over the counter? I looked inside of it today and there's a seal leaking or something and oil is getting all over everything.
    Tks
    89 Accord LX Coupe
    Vernon BC CANADA
    yes you can rebuild them but its probably cheaper to go to the nearest junk yard and pull one out...theres oring seals in there that need to be replaced
    is the oil coming out by the distributor were it meats the head or in the distributor>>>???????/ it wouldnt run if it was inside....
    so most likely it on the outside...theres an o ring you can replace...there like a 1$
    1986 Honda Accord EX (1.6) carb Manual
    Karachi Pakistan
    yeah you can rebuild the distributor - theres an oil seal embedded inside behind the main rotor and an o ring behind the camshaft key -
    When reassembling - ensure that the ignitor base is packed with silicone grease - its there to insulate water.
    SEi User MoonScryer's Avatar
    1986 Prelude 2.0si turbo - 1990 Integra moutain carver - 1993 Nissan 300ZXTT w/ more power than god
    Atlanta, GA
    Yes, you can rebuild it. If you get one from a junkyard, inspect it throughly. If it has "red dust" below the cover that sits below the rotor, it's bad, get another one.
    You can always hawk up the $300 for the rebuilt from the dealership :p
    I am the wrath of the server you curse and the demon of the directory you cry about - making life hell for users, one deleted file at a time.
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    Duno about rebuilt but from boneyard or ur car, certainly should be disassembled and clean it. Particularly the rotor shaft from main shaft, that's where burned oil/grease hardens and from where (i believe) red dust is coming from. Leave the bearing on the shaft is there is no play and seal is good.
    Here's exploded view: http://www.ualberta.ca/~dg5/Honda/EngElec/24-16.html
  1. Lazy man's distributor overhaul (TEC distributor)
    Last Post: 03-28-2019, 05:43 PM
  2. 88-89 Distributor on 86-87?
    By mzabeefy in forum 3geez Accords
    Last Post: 10-02-2006, 04:02 AM
  3. What distributor??
    By Kevin in forum EFI Tech
    Last Post: 07-14-2004, 02:18 PM
  4. Replies: 3
    Last Post: 09-06-2003, 01:03 PM
