I fitted the carb inlet onto the B20a today. I have the support from when the b20 was EFI and I have a pair of supports from the A20a that I took the inlet/carb from.
The supports for the carb from the A20a are way to small they dont reach the manifold by a few inches (the mountings on the back of the B20a block for the supports are totally differant)
The old B20a EFI support is not too far off and could be made to support one side of the inlet with a little fabrication.
How important is it to have both supports on?
Has anyone run a carb accord without these supports or at least with one of them not on?
I will see if I can fabricate someting for the timing belt end of the inlet manifold but the only bolt hole on the block is right at the bottom near the oil pan.
Ive attached a pic from the flywheel end of the engine of the carb inlet and the EFI support.
