So, I have a good question. I've noticed for about a month, an injector issue. Car seems like I have an injector that is either A)Dirty, in need of cleansing or B)Not getting sufficient contact. You can only tell a difference when you give it 20% throttle or more. Almost like a cylinder miss, but its not missing, just a cylinder that's not at complete full power. But when you lets off the accelerator, all cylinders run/fire perfect.
My number 2 and 3 cylinder Fuel Injectors have frayed old wire connectors at the injector plugs. Could this issue cause less resistance/power etc to the injector/s causing this? I drew out what kinda frayed connector I have. I'm stuck dispatching and can't get to the vehicle to take a picture. Could this frayed connection cause this issue?
Sent from My Samsung Galaxy Prevail
