Results 1 to 5 of 5
Thread: Timing bouncing all around, a20a1 , weber 32/36 carb, 1988 honda accord
    Jul 2013
    Trying to set my timing, but the timing marks are jumping all around.
    Tried this with the vacuum advance on and off and they're still bouncing. Any ideas?
    Also when I plug in the advance (the close one, not for cold starting). it does advance the timing, but it still jumps all around.
    Re: Timing bouncing all around, a20a1 , weber 32/36 carb, 1988 honda accord
    If you haven't done a tune up in awhile, that can cause erratic sparks. If that checks out, start looking for mechanical anomalies in your distributor, like a bad rotor bearing that makes the shaft slop around.
    cygnus x-1's Avatar
    Chicago area
    Look for sloppy distributor parts as Snooz said and also make sure the timing belt isn't loose.
    C|
    Nov 2006
    88 DX 5spd sedan 176Kmiles, 1 owner, stock. (Sold 10/18)
    Loose timing belt tensioner is my first thought.
    Look at the inductive pick up on the timing light, is it closed on the spark wire well , also swap spark wire with one that reaches, still use #1 for the pick up but rule out the wire breaking down and being erratic for the light pick up.
  1. Weber carb in 88 Accord.
    By Xaisk in forum Performance
    Last Post: 03-06-2010, 06:28 PM
  2. Timing issue with my 1988 Accord
    By TH1988 in forum 3geez Accords
    Last Post: 07-07-2008, 02:32 PM
  3. performance parts for a 89 accord dx carb A20A1 5Speed
    By josephgilpin in forum Performance
    Last Post: 11-16-2006, 09:34 AM
  4. 1988 Honda Accord LX Carb.
    By Sony in forum Classic Honda Pics & Videos
    Last Post: 02-17-2004, 07:40 AM
  5. 1988 honda accord carb?
    By geofstan in forum Carburetor Tech
    Last Post: 11-23-2003, 10:12 PM
