Results 1 to 11 of 11
Thread: How to change inner tie-rod ends
    bridgewater.NS Canada
    I want to change my inner tie rod ends as I have movement when I checked today.Is there a how to do it .I have another rack I can get them off of to use.
    Re: How to change inner tie-rod ends
    I ask because the haynes manual is useless.
    Download the manual from the wiki and check out chapter 18.
    I think I have that manual I'll check chapter 18 Thanks.
    The *.pdf manual is vastly superior to the Haynes.
    And that is an understatement!
    Well it doesn't tell u much,can u do it with the rack in the car and how long would it take.
    Exactly the same as most older Hondas.
    How To Replace Inner And Outer Tie Rods - YouTube
    Jul 2009
    Somerville, Alabama
    There is absolutely no comparison between the two. Haynes manual emphasizes mostly on the B20 accord. Here in America, that manual is nothing but a waste of time, money and knowledge. The FSM contains everything you need. Tis the Bible for 3geez. :-D
    I have to replace my inner tie rods still as well. The key is to remember to beat the special washer back so you can get the 17mm open end wrench on the inner tie rod. Good luck.
    Sent from My Samsung Galaxy Prevail
    Shaggy
    FF II/ETC I
    Jul 2009
    Somerville, Alabama
    Yes you can do it with the rack in the car. It would be alittle easier to remove the rack, simply because there isn't much room to remove/install the tie rods. Remember to pack the ball joints with grease. They'll prematurely fail if you don't.
    Shaggy
    FF II/ETC I
    Thanks guys,won't get to it til next weekend.Got to weld my exhaust this weekend.
  1. How to: Change Outer Tie Rod Ends (for dummies)
    By Toneloc5145 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-13-2008, 08:44 PM
  2. Never ends for me
    By Slipknotcraig133 in forum Performance
    Last Post: 08-01-2005, 02:41 PM
  3. inner tie rod ends.
    By TJ89Accord in forum 3geez Accords
    Last Post: 12-15-2003, 02:31 PM
  4. Wanted: Tie rod ends
    By MrBen in forum Trading Post
    Last Post: 11-07-2003, 04:21 PM
  5. Tie-Rod ends, do I need a puller?
    By 89AccordNate in forum 3geez Accords
    Last Post: 10-04-2002, 11:09 PM
