Results 1 to 25 of 25
Thread: Kraftaroni's Pics - Sweet Hatchback!
    Jul 2002
    Twin Weber DCOE Powered 88 Honda Accord LX
    Columbus, OH
    This guy can really build cars! Ask him about his 250 HP Dune Buggy sometime. His 3G looks great!
    Pic 1
    Mike Clark
    Jul 2002
    Columbus, OH
    Pic 2
    Mike Clark
    Jul 2002
    5 Speed 89 LXi Coupe
    "how low can u go??" geez son
    New Black Paint, Custom Gauges, Custom Interior Lighting, NEw Floor matts YEAHH!!!, JVC MP3 Head, Kenwod 6x9"s, Custom Mesh Grille,
    White Rims by Spring (17"s)
    Jul 2002
    Columbus, OH
    Pic 3
    Mike Clark
    Jul 2002
    Columbus, OH
    Pic 4
    Mike Clark
    SEi User johndej's Avatar
    1989 Accord LX-i 5 speed hatchback
    Culpeper, Va.- home, JMU (Harrisonburg, Va.)- school
    hmm....... looks pritty good to me. i wouldn't be able to go that low here (speed bumps and poor roads)
    "Eat, Drink, and be Merry!"
    2.0Si User Neuspeed87lx's Avatar
    Jul 2001
    96 Civic (Turbo lsvtec) /87 accord lx/95 civic dx
    Agawam, Mass
    that sh*t is slaaaaaaaaaamed ...very nice lookin
    Jay
    Oct 2000
    '88 Accord LX-i
    Connecticut
    Nice and low! I love it:smokin:
    '88 LX-i Coupe --- LS/Vtec
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    awesome! is it lowering springs or coilovers?
    Banned
    who knows?
    Forsyth, GA
    DAMN tose black rims are tight
    DX User kraftaroni's Avatar
    Oct 2000
    87 lxi, DC header, ported and cc'd head, lightened valves, bluprinted engine, shot peened rods, ross pistons, custom intake, 2.5 exhaust, isky cam
    Torrance
    Thanks for posting the pics site! I've been on this board from the old site and I've never posted a pic..I have tokico shocks painted them black and eibach springs I modified the spring perches by machining them down. I put st, swaybars and made a polyeuathane civic bushing kit 1/2 way fit! Not all of it worked... Had 16 O.Z.wheels then gsrs back in 94 sold them in 96 and got the racing sparcos 16in. I'm in the process of painting my car right now but i've been kinda busy. But I ordered the carbon fiber hood that site hooked up and its pushing me to finish the bodywork.
    86 Honda Accord LXI HB 5-sp
    Central California
    If I understand what I think I understand, you basically lowered the area the springs sit on, right? That's not a good idea at all cause your struts are effectively lengthened, the opposite of what you want running that low. Could you explain a little more on just what you did. A closeup pic of a spring perch would really do wonders
    Oct 2000
    Torrance
    I removed material from the lower strut perch or lower u strut holder they make lowered ones for other cars the bolt that usually has a slot on the front and rear strut had to be modified because it no longer fit in the molded slot. the pics I have of the suspension were before I did the mod...
    Central California
    In other words you removed the brake hangers and let the strut bodies sit down into the pinch forks a extra inch, right? That mod is a very good way to do it, cause if actually shorten's the strut body, good thing. But that only applies to the front. How did you modify the rears? Did you cut them above the lower mount and remove a inch of the body and have them welded back together?
    Now I d
    Oct 2000
    Torrance
    just removed the material off the top no an inch though the u hangers are cast and more than strong enough to remove aprox 1/2 inch or so if your courageous....
    Central California
    So you modifyed the pinch fork or did you modify the sturt body to allow it to sink into the pinch fork more?
    How did you do the rear's, is it like I said earlier?
    It's important me to fully understand what you did, since your the only one that's done this. I appreciate you explainting this to me.
    Now I d
    3Geez Veteran 87AccordsterLx's Avatar
    Nov 2001
    1991 Supra Turbo W/ 12k Miles
    Wyotech @ Laramie, WY
    wow this is crazy... I have one question for you... do you live in Torrance California???? If so then we need to talk......
    ~Nathan~
    "There's always something waiting at the end of the road. If you are not willing to see what it is, you probably shouldn't be out there in the first place."
    ~StOcK PiCs~
    LXi User pearldrop's Avatar
    Feb 2001
    93 Prelude Si..shaved and bagged - 96 S10 bagged and bodydropped, 99 Suburban dropped 5/7 on 22s
    NW Wash.
    I machined a half an inch off of the top of the wishbones to make it sit farther down on the Prelude. That is another option. It is still plenty strong and the only way left to get more drop out of the car.
    nice hatch indeed, the sparcos are a goos choice man...
    Aka mugenaccord from the ole ole ole board
    Pheonix Red CA6 -- Sold
    Grey ED6 -- current project
    Banned
    Oct 2002
    2000 Ford Focus SE 5spd
    Spencer, MA a bit outside of Worcester
    sweetness man.... that thing is mad slammed
    Jul 2002
    88 Accord (Australian Model Si)
    GoldCoast, Australia
    what is the difference between lowered springs and coilovers?
    Central California
    Lowering springs lower the car with nothing else other than shorter stiffer springs. Coilovers are stiffer lowering springs that have a threaded sleave that the spring perches can be moved up and down on, theirby lowering the car. The real reason for coilovers is to tune the suspension by weighing each corner of the car and adjusting them to shift weight around for better handling, not just to raise and lower the car to what ever ride height you want. But no one here use's them that way. Oh another reason to have coilovers is you can get special spring rates with the ground-controls.
    Now something else, on other car's you can get another type of coilover, it's a full bodied coilover, not a sleave type. With a full bodied coilover it comes with a matched strut that is designed for the spring stiffness in the coilover. The are extreamly expensive. 2 companies make them for our cars. One is doestech, I had some rear struts from them and they blew in 3K so the company sucks if you ask me. And the other is AIM intdustries, I haven't heard good things about them either and DXHATCHBACK bought them, but promptly returned them.
    Oct 2000
    Torrance
    I did exactly what peardrop did!! They sell "wishbones-strut holders-strut perched for other cars and there casted 2 inches shorter so I just cut off the tops.. And yes I live in torrance by South High.
    Nov 2001
    ok just clearing this up... is this the same torrance thats right next to Redondo Beach / Manhattan Beach...? If so then Im shocked that I have never seen your car... I lived in Redondo for 2 years... I just moved to GA but my sister still lives in the area so I was thinking that next time I go back to visit we should get a little local 3g's meet going... socal you interested???
    ~Nathan~
    ~StOcK PiCs~
    Nov 2001
    ahh I just read your profile... you work at the boeing building off of Sepulveda???
    ~Nathan~
    ~StOcK PiCs~
  1. 2 more pics of Rob's sweet accord!
    Last Post: 01-05-2003, 07:58 PM
