Results 1 to 25 of 25
Thread: 215/40/17 ok?????
    3Geez Veteran Coroncho80's Avatar
    Philly
    Question 215/40/17 ok?????
    I got this set of 17" rims with 205/40/17 Kuhmo tires. The rims sticks out a little bit and I was wondering if I'd be alright with some 215 tires. Here is a pic of what the rim looks like:
    Maurice
    2.0Si User Neuspeed87lx's Avatar
    Jul 2001
    96 Civic (Turbo lsvtec) /87 accord lx/95 civic dx
    Agawam, Mass
    you just wanted to show off your rims again
    Jay
    Philly
    :lol how did you know....................... No seriously, would i be alright with 215's?
    Maurice
    Oct 2000
    '88 Accord LX-i
    Connecticut
    Depends on a couple of things
    1) what is the offset of the rim? Maybe Jay knows. if its 38mm or 40mm then No, I wouldnt get a 215. If it is 42 or 45mm then you can.
    BUT!!
    2) How low do you want to lower your car? That all plays a role. too low and you will rub everywhere.
    '88 LX-i Coupe --- LS/Vtec
    Philly
    BUT!!
    Jay, little help ...............
    Maurice
    86 Honda Accord LXI HB 5-sp
    Central California
    Re: 215/40/17 ok?????
    Oh kay just did some research for you. The rims are 40mm offset. I went to whalentire to find out. BTW they sell your setup for $732
    http://www.whalentire.com/wheeldetai...D0440S&size=17
    And the other bit or research is I remembered that jigga225 is running 215/40-17. He rolled his rear fenders and here's the catch he's running 42mm offset and I'm pretty sure he has since said that he has rubbing problems. But I could be wrong about the rubbing. Pm him and ask him if, since he rolled his fenders if he ever has rubbing problems. At best it's very iffy, that you'll be able to run that size with 40mm offset. 215/40's are about 1/4" taller and 1/2" wider than 205/40's, both those facts work against you
    .https://www.3geez.com/showthread.php?...8421#post58421
    Now I d
    SiR's Avatar
    87 Accord LX
    Fort Lauderdale, Florida
    Black Accords are the shit!!! I just had to say that. 215 are pushing it. stay with the 205 you have. I have 205s on my 17's. They dont rub.
    Rooz
    Central California
    OH,... I can save you from writting a pm, no you can't run 215/40-17, they will rub. found this post by jason (jigga225)
    If you had 45mm offset, that might work.
    "my rimz are 42mm offset. 17x7.5 Helo Lotus.
    Cant slam it like I want rims and tires a lil too wide"
    __________________
    https://www.3geez.com/showthread.php?...5274#post75274
    Now I d
    SEi User jigga225's Avatar
    Louisiana
    look at my sig pic.. I'm not rubbin anything at that height..
    but if you want to go lower than THAT... youre gonna have some problems cause those tires are a lil wide (I dont know bout you but my rims are 7.5" wide)
    Jim put it pretty well tho.
    but youre cool wit the 215's man....
    I got a big box in the trunk, but if you dont ride rear passengers that much you dont have nothin to worry about.
    I know when I get more tires....I'm goin back 215/40/17.
    and Im not raisin the car up. Gotta stay loww
    Central California
    But, you've got 2mm of extra clearance that he doesn't have since his rims are 40mm offset. (thanks for replying jason).
    Now I d
    Philly
    Danm, that's some good info. Thanks guys.
    I wanna lower my car but I have no idea how low. I've never done this before, so this is all new to me. As you can see on the pic, the front is lower than the rear. How low should I go?
    Maurice
    Louisiana
    the front of the car looks lower than normal already.
    With my car, I liked it with a little less than two of my fingers gap all the way around, I dont have any problems that way....
    but Like jim said I'm not SURE if yours would rub that low or not.
    I think if you got the sprint 2.25" springs you would be good, and it would look tight
    Philly
    With my car, I liked it with a little less than two of my fingers gap.
    That's how low its in the front. The rear, I didnt touch because I also have a subwoofer box with two 12" MTX's, 500 watts each and that's pretty heavy.
    Maurice
    Central California
    You'll have to be the one to deside how low to go. Everyone has a different opinion on what looks right. The best thing I can say is to look at as many pics of lowered 3g's and pm the owners of the one's you like and see what they used to drop the car. Keep in mind that not all lowering springs offer stiff rear springs, if you've got heavy stuff in the trunk, you especially wounldn't want weak rear springs rates. The sprints are popular, but a few people with them have noticed that their front ends ride higher than the rear end, their not happy with that. Though their is a $70 fix to the problem. And you'll want strut's that and deal with stiffer lowering springs, that'll keep the ride quality closer to stock, even though it will ride firmer no matter what.
    Now I d
    Jul 2001
    Agawam, Mass
    hey guys ...the rims are 42mm offset ... i had those on my accord with it lowered 2.25 with sprint springs and a box with 2 12's in the trunk and it NEVER rubbed....i probally could have went 1/2 inch lower with no problems
    Jay
    Central California
    All the web sites I went to that carried those rims listed them as 40mm offset. The manufactuer's web site doesn't say what any of their rims are. And if I recall all the rim's in their entire line are 40mm offset, I know the 15's from maxxim I have are 40mm offset. Are they stamped as 42mm, or did they people that sold them to you tell you they were 42mm? The thing about rubbing is maurice was asking about being able to run 215mm tire's, not the 205's that are on their right now. As we both know, 205's and 40mm or 42mm offset's, won't rub. :super:
    [*edit*] update
    I went to maxxim's web site and used the application guide, their they do show the offset's for all the rims, including the konig line. The defcon's are 40mm offset for all size's.
    http://www.tiredex.com/konig/app_gui...ivic&B1=Submit
    Their about 3/4 the way down the page.
    Now I d
    Jul 2001
    Agawam, Mass
    those arent maxxim wheels
    Jay
    Central California
    Hey wait a minute, that's not what you said when you were selling them, what's going on? Then what rims are they, model and brand?
    "wheels for sale
    a have a set of 17 inch rims for sale ...the rims are maximm rims and they have bf goodrich scorcher tires on them...the tires have a colored strip going down the middle of them ...the strip is yellow ..see the tires .Here there the 205-40-17 ....they are in almost new shape . ...the rims are also in excellent shape ...no scratches...no flaws...i want to get 900 for them..here is a pic of the rims on my civic"
    https://www.3geez.com/showthread.php?s=&threadid=7556
    Now I d
    Philly
    Dude, those are not the rims that he sold me. This are the rims he sold me...........
    Maurice
    Jul 2001
    Agawam, Mass
    lol ...thats the other set i have for sale i have 2 sets...well now i have one set 4 sale ...those maxxims are still for sale
    Jay
    Philly
    Yo, I think I know somebody around here who is looking for a set like yours man. Let me give him a call tomorrow and I'll let you know alright..............
    Maurice
    Jul 2001
    Agawam, Mass
    sweet! thanks
    Jay
    Central California
    All righty, now I get it, but you still didn't answer my question. What rims did you sell to maurice?
    Now I d
    Philly
    I think they're a set that he stole from the flea market or something............ :lol
    Maurice
    3Geez Veteran 87AccordsterLx's Avatar
    Nov 2001
    1991 Supra Turbo W/ 12k Miles
    Wyotech @ Laramie, WY
    HAHAHA... they're the $9.99 special!!!! too funny.... I think they look good...
    ~Nathan~
    ~StOcK PiCs~
