Results 1 to 6 of 6
Thread: Loose Caliper
    Jul 2009
    Somerville, Alabama
    Loose Caliper
    I noticed today, my caliper is loose. I can move it by hand probably about a ¼ inch in/out. The bolts that hold it to the bracket are FSM spec torqued...yet it is still floppy. What could be causing this? Is it somehow warped?
    Sent from My Samsung Galaxy Prevail
    Shaggy
    FF II/ETC I
    Re: Loose Caliper
    Calipers is a floating design. I think when you press the brake pedal a release it you will find it centered up and is tight again.
    You can replace the pins that the caliper rides on this would fix a rattle you here hitting small bumps or the bracket also with the pins. I noticed no rattle with new brackets and new pins when I upgrade my front brakes.
    Re: Loose Caliper
    It shouldn't affect braking performance, but you might notice an annoying rattle when you drive over bumpy roads as well as having the dreaded front end wobble when braking at high speed.
    Re: Loose Caliper
    Mine move a slight bit as well. I think it is just the design of it.
    cygnus x-1's Avatar
    Chicago area
    Re: Loose Caliper
    It could be that the pins are worn making the caliper sloppier than usual. You can get new pins from Rockauto and probably even the local parts store.
    C|
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    Re: Loose Caliper
    it can also be the bracket that wears out where the pins slide into. Had an issue back on my old 87 that i converted to the 88 89 front brakes. I've noticed a small "clunk" when pulling out of my driveway, turned out to be excessive play in the slider pins and the brake pad clips causing the pads to move around. When you replace the pins make sure you grease them well
    3Geez resident body man
    Owner of Wreck-less auto body
  1. [Suspension, Wheels, Tires & Brakes] Rear Caliper Upgrade, Legend Caliper (with Pics)
    By Legend_master in forum How To
    Last Post: 04-29-2012, 11:32 AM
  2. Jdm caliper
    By cahitapower in forum 3geez Accords
    Last Post: 03-23-2012, 05:51 AM
  3. URGENT ASST. PLZ! Brake Caliper Frozen on Caliper Pin!
    By ascender in forum 3geez Accords
    Last Post: 08-03-2003, 07:38 PM
  4. my ass end gets a little loose
    By marc49 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-14-2002, 06:49 PM
  5. let loose
    By mag_pbg in forum Classic Honda Community Chat
    Last Post: 06-14-2002, 12:23 PM
