Results 1 to 13 of 13
Thread: Just Starting Pinging!
    Dec 2012
    1989 Honda Accord LXi
    I have an 89 LXi with about 235k miles on it. I have noticed that ever since I've had it, if I am cruising around half throttle and I go to floor it, it pings. Well lately it's pinging on almost every acceleration pretty badly IMO.
    I have only used 87 octane since I've had the car. Recently I retarded the ignition timing and it didn't help. Now the distributor is retarded to the max and it still pings like crazy. I sea foamed the motor and that didn't help. I tried running octane booster and that didn't help either. Where does this leave me? EGR valve?
    Side note, the weather hasn't radically changed or anything like that.
    Jul 2009
    Somerville, Alabama
    Re: Just Starting Pinging!
    Quote Originally Posted by stuntjunkie199 View Post
    Your O2 sensor may be bad or going bad. Your Intake Temperature Sensor could be going bad as well. I would check the resistance on them and see if they're within spec.
    Shaggy
    FF II/ETC I
    Mar 2003
    2004 Acura TL
    Arkansas
    Have you verified that the advance controls inside the distributor are working? Twist the rotor and make sure it springs back. Apply vacuum to the advance and make sure the pickup moves.
    Also, with that many miles are you sure its pinging and not rods knocking?
    Dec 2012
    Yes I'm sure the rods are not knocking; this is more of a faint metallic sound, kind of like putting BB pellets into a soda can and shaking it.
    I did get a code for O2 sensor the other day but it went away immediately, I didn't know this could affect the pinging. I will definitely check that when I get a chance. Where is the intake temp. sensor? Or if you had the page in the shop manual that addresses this, I could figure it out.
    Thanks
    Mar 2003
    2004 Acura TL
    Arkansas
    Yeah, if the o2 sensor is reading too rich it will cause the engine to run too lean, which can cause pinging. Usually I've seen them fail the other way where the sensor reads too lean, and the computer tries to keep adding fuel and finally gives up.
    Jul 2009
    Somerville, Alabama
    Does the O2 sensor potentially causing pinging only apply to the 88-89 or the 86 to 87 as well?
    Sent from My Samsung Galaxy Prevail
    Shaggy
    FF II/ETC I
    Dec 2012
    Are both O2 sensors exactly the same? If so I could just order two of the same part?
    Jun 2011
    89 LX-i sedan
    Garden Grove, CA
    The length of the wire from the sensor to the connector is different but the connector and sensor are the same. I just replaced mine a couple of months ago, got the left and the right from RockAuto.com. they were about the same price for each side and both were Denso. If you get the universal where you cut the wire from your old sensors and attach it to the new sensors, they are the same.
    Dec 2012
    Alright I checked both O2 sensors. Sensor "B" read fine within spec. Sensor "A" however read 0.6 at idle and close to 1V at 5K. The manual says it should be at 0.6 at 5K. Is this enough out of spec to warrant pinging?
    Jun 2011
    89 LX-i sedan
    Garden Grove, CA
    The manual say it should be above .6v at 5k so 1v is fine but it should drop below .4v when quickly released from the 5k or below 2k depending on the manual. Since sensor A does not go below .4v at idle it should be replaced. It might contribute to the pinging but it might not be the only thing. Personally I would replace both at the same time because the other one is likely to go soon
    I would double check your timing belt at TDC make sure its not installed 2 teeth out. When I bought mine it was.
    Dec 2012
    Alright, I'll order O2 sensors tonight. We'll see what that does for the pinging.
    Dec 2012
    Pinging fixed!! Put the new O2 sensor in this evening and all is good! Thanks for help. Now to reset my timing...
  1. Pinging under partial throttle
    By Vanilla Sky in forum 3geez Accords
    Last Post: 07-28-2015, 08:10 AM
  2. Blow by,Misfire,pinging
    By JdmCA9 in forum 3geez Accords
    Last Post: 04-13-2013, 02:29 PM
  3. HELP, car is missing pinging
    By t-bone in forum 2geez Accords
    Last Post: 08-02-2009, 11:07 PM
  4. Pinging
    By Mars in forum 3geez Accords
    Last Post: 12-14-2005, 11:58 AM
  5. hot pinging action
    By ShawnS in forum 3geez Accords
    Last Post: 02-19-2003, 11:02 AM
