Results 1 to 6 of 6
Thread: '98 Honda Accord Driver Door Will Not Open From Inside or Outside
    Aug 2013
    1998 Honda Accord
    Hi, fiance has a 1998 Accord. We went to store and came back to car to find that the door will not open from outside or inside the car.
    Apparently she said that she researched this a bit and found that this is a notorious problem with the Honda Accord? I'm not sure what she found specifically, but she said that she read that there is no way to open the door aside from cutting a hole in the door?
    This is no bueno because we have a 1 1/2 yr old that she has to take everywhere... and not to mention she is also pregnant again at the moment , so she cant be sliding in through the window or other door.
    Please, does anyone know about this problem? Is there another solution aside from cutting into the door
    Mar 2003
    2004 Acura TL
    Arkansas
    Re: '98 Honda Accord Driver Door Will Not Open From Inside or Outside
    Notorious problem on 4G, 90-93. I've personally not seen it on later accords. But it's been a while since I've been in the game.
    Aug 2013
    1998 Honda Accord
    Quote Originally Posted by Jafir View Post
    Jafir, any tips on how to go about fixing? How can I get the door open?
    Mar 2003
    2004 Acura TL
    Arkansas
    There was a TSB or servicenews post about drilling the latch in a certain place to free up whatever was stuck. The last one I saw was a 4 door 10 years or more ago, and we removed the trim on the B piller, cut an opening, and drilled out the strike plate from the back. Then we replace the strike plate, and latch assembly.
    Before assuming it's the same problem though, I'd try to remove the door panel and make sure something didn't just come unhooked.
    Aug 2013
    1998 Honda Accord
    Thanks! Do you think that any of these 3 methods would be useful for me as an alternative to drilling the lock?
    1. Youtube Video 1
    2. Youtube Video 2
    3. Thread about this issue on another forum
    Thanks again for your help! I have no idea what I would do if I didn't have someone to point me in the right direction
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    I don't know if you're still working on this, but I had the same problem a couple months ago. My comments are near the end of the thread.
    Driver side door stuck! - 6th Gen Accord DIY and Performance Forums
    The summary is your youtube video 2 instructions worked for me. Be sure to make a tool that looks like theirs.
    Mike
  1. cant open car door driver side
    By accord1989 in forum 3geez Accords
    Last Post: 05-08-2010, 01:42 PM
