well I just got from emmisions and my sedan weighed in at 2750 lbs.. thats with a dual sub box enclosure... I was just wondering what its supposed to weigh... oh ya by the way.. does our car have an EGR valve???
~Nathan~
"There's always something waiting at the end of the road. If you are not willing to see what it is, you probably shouldn't be out there in the first place."
~StOcK PiCs~
I know the 89 LXi has an EGR valve, but I'm not as familar with the emssions junk on the carbed cars. I think they all have it too though. If you've got a small pipe threaded into your exhaust header, then you also have an egr valve.
The coupes and HBs weigh 2500-2600 lbs. and the sedans weight about 2700 lbs. Transmission and trim level also make a difference.
Mike
cool.. thanks.. I'll have to check on that.. I think the pipe threaded into the header connects to the air intake return... is this the same pipe that you are refering to???
~Nathan~
~StOcK PiCs~
yeah carb engines have EGR.
ok so do you think that a bad/old egr valve could be one reason that I failed emissions??? Im going to get a new hi-low cat and fix my timing but could that be one reason?
~Nathan~
~StOcK PiCs~
