Results 1 to 15 of 15
Thread: Possessed Car
    89 SEI Honda Accord
    Attending college in SC but actually from the U.S. Virgin Islands
    Possessed Car
    When I have my car in park sometimes, the car revs by itself. for example, it goes from 1,000 to 3,000 rpms and I am not touching anything. I just had my transmission replaced. Please someone tell me what it might be, i'm thinking that maybe it may be my fuel filter because i have never replaced that but i'm not sure. Thanks for the help in advance.
    Canman. Reppin for the VI till the day I die.
    1988starter
    Guest
    when does it do this when its cold ward. Try cleaning your throttle body
    LX User 89LXiCoupe's Avatar
    1989 LX-i Coupe
    California
    On your throttle body, there's a screw. It could just be the screw that is loose that needs to be tightened.
    "Please don't hesitate to use full throttle."
    88 Lxi/ 5spd
    Tennessee
    its not the fuel filter
    In the end...it doesn't even matter.
    88 Lxi, 5spd swap w/ Aasco 8lb flywheel/Cai,AccelCoil,NologyWires,SilverstoneSparks/DC421,ColtCam,Remachined Head&Tb...NitrousWorks 40shot
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Does the rpm go up and down up and down or just up and stays there?
    Oct 2001
    87 Accord EX , 5spd , Manual
    man ! i 've heard this problem a lot in EFI guys ! and still didn't find a straight answer that can be put in the faq !
    MIKE
    Banned
    Oct 2002
    2000 Ford Focus SE 5spd
    Spencer, MA a bit outside of Worcester
    i dont think it's the throddle body i think it really is possessed......
    Banned
    Oct 2002
    or it could be that the throddle cable it loose or to tight, yea that's probly it not the whole possessed thing
    LXi User original2k's Avatar
    88 Mugen Accord
    Fairfax, VA
    lol u all sound so funny, in the owners manual it states that this usually will happen in cold climates, in fact it happens to my car everyday, start her up revs to like 3000 and stays there, after like 5-10min after it begins to warm up the owners manual says to press the gas in (which will make it rev to like 3-4000) and slow release it, which works cuz i do it every morning since it's gotten cold here, i'm not sure what the cause is, but u shouldn't be alarmed.
    "Accord"........we are one........
    Oct 2002
    1986 Honda Accord EXi
    Niagara Falls
    Have you ever replaced the thermostat? If so, make sure it's a 192 degree or higher if your in a colder climate. This might make a difference.
    10/Honda/Ridgeline
    NJ
    fast idle is high for a carb than a efi, if a efi does this, then its something wrong. it could be ur fast idle valve on ur TB
    Oct 2002
    1988 Accord LX
    Vancouver
    I don't know if this answers anything, but I get that issue right after I change the oil and filter. It only happens a couple times then goes back to normal.
    1988 Accord LX, Bosch Wires, NGK Plugs, K&N Filter, bla bla bla
    10/Honda/Ridgeline
    NJ
    hmmm... thats a really interesting thing u just said caddy. i have no clue why the car would do that right after u change the oil. Hmmm.... my guess is that it could be ur PCV valve leakin. check to see if its leaking and if not i have no clue what might be wrong, consdering that u say it happens right after u change the oil.
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Banned Neuspeed007's Avatar
    Oct 2002
    1995 Civic Ex
    BOISE IDAHO
    mine does that in the morning when i havent let it warm up all the way.
  1. my radio is possessed
    By evil88accordLX in forum 3geez Accords
    Last Post: 07-10-2007, 11:28 AM
  2. Possessed Engine
    By Andibogard in forum 3geez Accords
    Last Post: 10-25-2003, 10:05 AM
  3. Speedometer is possessed
    By MrBen in forum 3geez Accords
    Last Post: 03-15-2003, 10:35 PM
  4. Possessed Car
    By kennycm in forum Performance
    Last Post: 11-08-2002, 12:57 PM
  5. my Brakes are Possessed
    Last Post: 07-24-2002, 06:36 PM
