Results 1 to 13 of 13
Thread: Help! 1982 Accord Weber conversion, now blue smoke and runs like shit!
    May 2010
    2001 Honda Accord,1982 Honda Accord LX, 1982 Honda Prelude, 1989 Honda Accord LXi (RIP), 1988 Honda Accord DX (RIP)
    Oklahoma City
    Last week, I converted my 1982 Accord to a Weber carb. I drove the car about 150 miles and it did great. Over the last few days/75-100 miles the car has been producing more and more blue smoke and burning more and more oil. Also, the idle and acceleration have got progressively worse. It was running GREAT the first 150 miles after the conversion! Thanks for any help!
    LX User charliefowle03's Avatar
    Mar 2012
    1983 Honda Accord automatic EK1
    Columbus Ohio
    Re: Help! 1982 Accord Weber conversion, now blue smoke and runs like shit!
    Quote Originally Posted by Twiewel89lxi View Post
    I have had very similar experience after my cinversion. I had to redo my gaskets 3 times and apply different sealants to help the gas leaks. Right now they are doing ok with some aviation sealant. like a sappy consistency..messy but has help up well. as far as the oil burning i would lokk into the coolant system. check for leaks ect temp gauge be noteful of. the oil burning may not be realted to the weber swap.
    What did you do with the PCV when you converted?
    May 2010
    Oklahoma City
    Thanks for the help. The gaskets seep to be sealed just fine. As far as the PVC, I wasn't aware there was one. I just have the valve cover connected to the air cleaner. The only other things I've done are connect the distributor to the carb, and the fuel and brake booster line. What did I miss?
    You're right, there is no PCV system on the EK motor. Sounds like you've got it right. Have you double checked that your float didn't go all wonky? Perhaps it's got a pinhole leak and is no longer floating.
    Jun 2013
    82 Accord
    Pull the top of the air cleaner off and see if it's all oily in there, maybe the crankcase vent is just letting too much oil through. If not I would do a leakdown with the valve cover off and check around the aux chamber seals. Could be that they were marginal before and the change of vac characteristics with the weber and ditching all the smog junk made it worse. Burning oil and loss of compression would sure make sense here, if thats the case I'd do valve stem seals also(aux valve seal set comes with seals for the chambers). All of this can be done on the car but much easier to remove the aux chambers with the head off, I even left the manifolds on the head and pulled the whole assy, but I had a bad head gasket also. Could also be you're just running too lean and burned up the rings, that would suck but a compression and leakdown test will tell ya for sure.
    Wait. Isn't there a breather on the valve cover that goes into the air cleaner?
    LX User 2geeSEi's Avatar
    Apr 2010
    1985 Accord SEi
    Riverside, California, United States
    He mentioned that he has it connected.
    May 2010
    Oklahoma City
    Ok, so I hooked the same carb up to my '82 prelude and it started smoking instantly... It was fine before. Any ideas?
    How's it run though? Maybe it's running way too rich or something? I can't fathom why it would do this...
    May 2010
    Oklahoma City
    It's running great. My only concern is that the Accord ran great at first too.
    You try putting the stock carb back on and see if it still does it? How much smoke are we talking about?
    May 2010
    Oklahoma City
    On the Accord it was A LOT of smoke out of the tail pipe and under the hood. On the Prelude, very little and mostly from under the hood.
  1. '82 Accord Weber conversion smoke ???
    By schatzi in forum Carburetor Tech
    Last Post: 08-23-2009, 07:26 AM
  2. car runs like shit w/safc...
    By Rendon LX-i in forum 3geez Accords
    Last Post: 07-26-2008, 03:31 AM
  3. blue smoke after 6 wks storage
    By w261w261 in forum 3geez Accords
    Last Post: 01-21-2006, 07:55 PM
  4. Blue smoke
    By MrBen in forum 3geez Accords
    Last Post: 05-31-2003, 07:14 PM
  5. So, I have blue smoke.
    Last Post: 05-09-2003, 01:20 PM
