Ok, I'm trying to install the streetlights pedals over my brake and gas, the break went on easy but the gas pedal is to big. Does any one know how to remove the gas pedal from an automatic, so that I can drill holes in it real easy.
i ran into the same problem when i put my new pedal covers on. the gas pedal was to wide, so i took my grinder with a cutting wheel on it and cut a slit in the pedal, so the brakets holding the new covers on will slide onto the gas pedal. but to answer your question ive never taken the gas pedal out. so try drilling or whatever with it still in...
I think I may try what you did.
