Just pulled mine out to check why battery indicator was coming on, and ran into a snag. There's NO way to get it out! Carb is in the way up top, the axels are in the way from below, the mounting bracket is in the way to the side, and the other side.. well that's why I'm posting. If you ever have to take one of things off, here ya go:
1. Remove the air cleaner assembly, note where the vacuum hoses go, make sure not to tear any.
2. Remove the air box, there's 2-3 bolts holding it on, they should all be 10mm. It's the little black plastic box connected to the air assembly with a black plastic hose.
3. Remove the bolt holding the top of the alternator to the bracket, I also loosened the adjustment screw, just in case. Both are 12mm.
*WARNING* Do NOT lose the washer that goes between the alternator and the bracket. Alternator-washer-bracket-bolt.*WARNING*
4. Remove the cables, there's one with a pinch connector, that's the main one, and there's one with a boot, and a 10mm nut on the top.
5. Jack up the car, and remove driver wheel. May not be necessary but MUCH easier.
6. Remove the bolt on the bottom of the alternator. 14mm
7. Get a decent length screwdriver and a hammer, and tap on the bottom of the alternator to push it up out of the bracket.
8. Remove the heater hoses going into the firewall, and disconnect the heater switch control cable, move them out of the way.
9. Shimmy the alternator over the transmission bracket and up out the side near the vacuum hose box.
10. Shimmy the new one in the same way, and reassemble.
Hope this helps anyone concerned that they are told to remove the cv axle to get the darned alternator out of there.
On a FI accord, remove the airbox, and just pull the alternator straight up. MUCH easier.
