Results 1 to 8 of 8
Thread: Wheel Offset Question!
    2003 Nissan Sentra SE-R Spec V
    Daytona Beach, FL
    Question Wheel Offset Question!
    Hey guys. My friend just picked up an 89 Accord LXi Hatch. He used to drive an 84 Supra. Anyway, he wants to know if there is some kind of adapter to make the supra wheels fit since the offset is the same. They are both 4 lug though.
    Any help will be appreciated. Thanks!
    Chris Jones
    Hotshot CAI, Hotshot Header, Thermal R&D Exhaust, AC Autotechnic Reverse Indiglo Gauges, SW Autoworks Pulley, ES MM
    14.9 @ 93mph
    86 Honda Accord LXI HB 5-sp
    Central California
    Re: Wheel Offset Question!
    This web site that deal's with the 82-85 celica/supra say's that factory supra rims are 8mm offset, which I know is true since those car's are RWD and their rims stick out from the hubs quite a bit. (The 86-90 celica's went to a fwd chassis and may use rims simular to ours.) You cannot fix this in anyway, those rims are not useable. Using a spacer would only make the problem worse by moving the tire in further away from the hubs towards the fender lips even more. And with them being 7" wide, it would make a 195/60-14, look kinda funky when mounted, IMO.
    http://www.celicasupra.com/wheels.htm
    Now I d
    Daytona Beach, FL
    Thanks dude, that solves that question.
    He was gonna use the 225 width tires that were on those rims anyway. An accord with 225 would probably be sweet if it didnt stick out too much.
    Chris Jones
    14.9 @ 93mph
    Central California
    Your welcome, I'm positive that 225 will flat out not fit in the back, even with the best possible offset for wide tires, 45mm and even with the rear fender's rolled. And in the front I'd worry about the tire clearing the bottom of the strut/spring perch.
    I think I've heard of someone running 225 in the front and something narrower in the rear, but I just don't see 45mm offset and 225 being possible, even 40mm offset and 225 I doubt.
    Daytona Beach, FL
    So whats the widest tire you can put on the stock rims and what profile should he get to keep the speedo on?
    Chris Jones
    14.9 @ 93mph
    Central California
    Well I just did some reasearch and the they don't offer 205/55-14 tires in anything other than autocrossing tires (with 50 tread wear ratings) and I tried 215/50 and even 205/50, none, no tires in those sizes.
    But you can get 205/60-14, but their are a full inch taller so the speedo will be off and that extra tire height presents clearance problems. I will say that they just might work, I'd find that size at a used tire shop and pay $5 to have it mounted to check clearance's
    Here's a list on the 205/60-14's that tirerack carries.
    http://www.tirerack.com/tires/Compar...rk=1&do=Search
    Now I d
    AZmike's Avatar
    Tucson, Arizona
    Sorry Jim, but 205-60-14 isn't an inch taller than 195-60-14
    205-195=10 mm
    .6*10*2=12mm = 1/2" ish (25.4mm = 1 in)
    My Accord had 205-60-14s when I got it and I went ahead and stayed with it. I drive highway so much I figured I could give up the little bit of torque for the better mileage and longer treadwear. I've checked and my odometer is stillc orrect (verfied by GPS) and my speedometer still reads high.
    Mike
    Central California
    205-195=10 mm
    Na don't be sorry for being right I know what I did wrong, I glanced at 15" instead of 14's. Your right they are 1/2" taller.
    Now I d
  1. Wheel opinion/offset help
    By canadian357 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-15-2010, 09:25 PM
  2. Wheel offset
    By mix4 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-09-2007, 11:14 PM
  3. Offset for wheel sizing
    By ProfileTrader in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-31-2006, 08:52 AM
  4. Wheel offset question
    By Dr._8t9LX in forum Classic Honda Community Chat
    Last Post: 12-04-2004, 06:39 PM
  5. Wheel offset.
    By Hash_man_Se_i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-07-2004, 04:50 PM
