Results 1 to 17 of 17
Thread: Idle Issue
    bridgewater.NS Canada
    Idle Issue
    So yesterday my idle starts going up to 1500 at stop ligh,then creeps down to 1000.I took off iacv and cleaned it.but today its doing the same thing,took out idle screw and cleaned it and sprayed some TB cleaner in there.what else could cause this.Coolant is up so thats not it.what else can I check.
    Re: Idle Issue
    Vacuum leak.
    Exclamation Re: Idle Issue
    I looked but couldn't find one,gonna check coolant again and bleed it just to be sure.could it be intake manifold gasket,I swapped to the b-series couple months ago.
    Re: Idle Issue
    What, you mean like this?
    Re: Idle Issue
    So i'm still having idle issues sometimes,but this morning when i got to work i stopped to back in parking area and car was at 2000 on tack when stopped when i went to leave it was fine.any idea what would cause this.
    Re: Idle Issue
    Might be time for a new IACV.
    Re: Idle Issue
    Agreed, does sound like IACV. Try blocking it, and see if that solves the situation.
    Re: Idle Issue
    Can u eliminate the iacv all together or do I need it.I'll try and block it off and see if it gets better.Are all the b-series the same,iI think mine is off a 91.So do I use a piece of plastic to block it off.
    Re: Idle Issue
    No they are all different. You should get one from a b16. I just used a piece of cardboard to block it off. You can not eliminate it. The system has to have the IACV connected.
    Re: Idle Issue
    Nevermind.
    Re: Idle Issue
    Ok thanks legend,why the b16 one
    Re: Idle Issue
    Because it is the closest to the a-series that has been found. You LS may work, but it is uncharted territory.
    Re: Idle Issue
    So is that a dealer item or does parts stores handle them,what is the best car to get one from.I can check the j/y for one.
    Re: Idle Issue
    You should check out Google. For real man, TON of information about b16 motors.
    Re: Idle Issue
    So i talked to a guy at work who used to work at honda,he said to take the cover off the fitv and turn it out a turn.He said it shouldn't be turned in all the way,going to try this on the weekend.
    Re: Idle Issue
    The idle control system is described in detail on pp. 12-43 and following in the manual. Lots of troubleshooting info, etc. There is also a symptom chart on p. 12-40.
    Re: Idle Issue
    I'll take a look thanks snooz.
  1. a/c idle boost issue
    By zebratow in forum Carburetor Tech
    Last Post: 11-29-2009, 07:15 PM
  2. Idle Issue After Rebuild & Other ?'s
    By chadew in forum EFI Tech
    Last Post: 04-26-2009, 04:03 PM
  3. Very Weird Idle Issue please help me
    By 1988starter in forum 3geez Accords
    Last Post: 02-05-2004, 05:00 PM
  4. Idle issue
    By Fueldrum in forum Classic Honda Community Chat
    Last Post: 01-23-2004, 12:16 PM
  5. Idle issue(intermitant)
    By Zayden in forum 3geez Accords
    Last Post: 09-04-2002, 07:29 AM
