Results 1 to 10 of 10
Thread: Please help Me
    1988starter
    Guest
    Please help Me
    Ok when My girlfriends 86 accord LX is below about 2K the battery light stays off but above it it comes on. I can get it to go off when I put the heater and the lights on along with the fan but other than that I cannot. I just changed out the voltage regulator and the brushes there is no rust on it or the contacts. Any hints on the problem.
    Oct 2000
    '88 Accord LX-i
    Connecticut
    I think the alternator is going to take a shit, but I am not 100% sure.
    '88 LX-i Coupe --- LS/Vtec
    1988starter
    Guest
    Also the car is carben and the alternator has 4 pins I thought only efi had 4 pins. are the alternators the same except that.
    Oct 2000
    '88 Accord LX-i
    Connecticut
    the alternator for a carbed car should only have 3 pins. The DX i bought came with a shitty alternator and when I bought it the seller included one. The one he included was for fuel injection. If the one on her car does have 4pins that could be the problem, but I dont see how it would fit the connector.
    Carbs - 3pins
    Fuel Injected - 4pins
    1988starter
    Guest
    I swear it has 4 pins and it is a carb the connector will not even fit three pins.
    Oct 2000
    '88 Accord LX-i
    Connecticut
    hmmm lol I am stumped. All I know is that carbs=3pins and FI=4pins
    1988starter
    Guest
    help anyone else
    Oct 2001
    87 Accord EX , 5spd , Manual
    someone had this problem before and it was the alternator belt slipping and the light always came on under 2.5 K rpm !
    but i am not sure ! but you could check that first before replacing an alternator !
    MIKE
    LXi User Don87LX's Avatar
    Weber'd LX
    Virgina.
    get a voltage guage. you can get the nice in dash kind or the temporary cig lighter kind to measure the altenator output. IT should be at or around 12 volts just about all the time. If it is low or fluctuating wildy then I would imagne the altenator has difficulties. I think you can even get AutoZone or someplace similar to test your altenator for free. At least I'm pretty sure thats how it you test it. If I am wrong someone please call me on it.
    as for the four pin connector....
    Accord has been replaced with a 2004 Solara SE Sport with 3.3 VVT-i V6...man does that car move...
    A alternater is to hard to take out on 3-g's. Put a voltmeter across the battery it should read 12 volts,then start it it should then read 14 or so volts running. If low then take it to the zone.
