Results 1 to 8 of 8
Thread: Must Read, I Need Help!!!!
    87 honda prelude si 2.0 l
    Oregon
    i am changing my old clutch out in my a20a3 engine......the release arm was hard with the worn-out clutch, but when we put in the new clutch, the release arm was really easy to move up.....now that we have spent 4 days straight putting the car back together, the car will not go into gear at ALL. i push in the loose clutch and it won't allow it to go into gear. YES, we tighten the clutch cable as far as we can....so we know it has to do with the release arm, but we don't know what we did wrong.... we are trying to find out the problem, but please give me imput if you have any idea what the problem might be......thanks
    Jeremy
    89 Accord LX Coupe
    Vernon BC CANADA
    um id say that the release arm is on worng or you forgot to put the throwout bearing on or on right.
    or the clutch could be on worng...
    you should not be able to move the release arm by hand easy if not at all
    BEn
    Oregon
    i am stuck and need to know how to fix the release arm before i tear the block apart again!!!!????
    Oct 2001
    87 Accord EX , 5spd , Manual
    did you change just the disc and the pressure plate ?
    MIKE
    Oregon
    i changed the disc, pressure plate and new flywheel.....it all lined up and i am almost exactly sure that it is the right parts..i am tearing it back apart saturday, but i have no idea what to look for......
    88 Lxi/ 5spd
    Tennessee
    This doesn't make sense. If the lever moves freely then lets look at our options. 1.Its not moving the release fork and is broke. 2. You have no throwout bearing or the spring snapped and the bearing isn't in position. 3. There is no pressure plate. 4. You have something wayyyyyyyyyyyy out of line. Lets go through the steps here. When you press on the clutch that should pull the lever up and move the fork .....release bearing should make and break contact against the fingers on the pressure plate as you press in and out on the clutch .....if no pressure is felt then the bearing isn't contacting the pressure plate.
    In the end...it doesn't even matter.
    88 Lxi, 5spd swap w/ Aasco 8lb flywheel/Cai,AccelCoil,NologyWires,SilverstoneSparks/DC421,ColtCam,Remachined Head&Tb...NitrousWorks 40shot
    PhydeauX's Avatar
    Eastern Penna
    You didn't put a 1.8 flywheel and clutch in did you?
    andy
    Oregon
    i think it is the release fork......it must be, i just talked to a mechanic and he is going to help me out, thanks guyz...
  1. Read First
    By A20A1 in forum Newbie Introductions
    Last Post: 08-18-2007, 04:49 PM
  2. Did I read it right?
    By Terremotico in forum 3geez Accords
    Last Post: 02-14-2006, 04:58 PM
  3. I Know I Read This Somewhere
    By BigLem504 in forum Performance
    Last Post: 05-13-2004, 07:39 PM
  4. **please Read**
    By 89lxi95zx7 in forum Classic Honda Community Chat
    Last Post: 11-12-2002, 10:31 AM
  5. Need help QUICK: Read read!! hurry !
    By pimp86LX in forum Interior & Exterior Care
    Last Post: 10-31-2002, 01:22 PM
