Results 1 to 9 of 9
Thread: Brakes squeal when not pressed...
    Jun 2002
    86 Accord LX, Carb, AT
    About 3 days now, my brakes (actually, I think just the right front disk) have been making a grinding noise whenever they're not depressed... If I push them in even lightly, the noise goes away...
    Haven't quite established the below as a rule, but it seems like it... anyways - if I push the brake pedal lightly a few times while driving, it feels as if resistance in the brake pedal gets higher, and the noise disappears, even with the pedal released.
    So, not sure what's going on... I'd think if the pads were bad, the noise would happen DURING braking, not the other way around..
    Any ideas what I should do?
    Thanks,
    2Fast
    Oct 2002
    1988 Honda Accord LXi
    We'll actually sometimes when they get REALLY bad they do this sqealling thing..
    Usually its the little metal tab that lets you know when your brakes are bad most of the time when it gets this bad the rotors need to be resuraced.. not sure if this is the case but im sure you should deffaintly take a look at your pads/rotors. ..oh and somtimes the capilers lock dup. Ive had a few girlfriends that have let there brakes get so bad the ribbets that hold the pad onto the metal made a nice circle almost cutting the rotor in half.. anyway I hope it isn't quite as serve in your case.. good luck... and hope you get your problem sorted out... latter
    SiR's Avatar
    87 Accord LX
    Fort Lauderdale, Florida
    Almost sounds like there is some play in the hub or the rotor is loose from the hub, which seems unlikely. Check if the caliper is loose from its mounts. or if the pads are loose from its brakets.
    Rooz
    89 Accord LX-i coupe, Auto
    Missouri
    that happened in my old car, but it had tons of brake problems so i don't know what exactly caused the squelling, but i think that is caused by ur brake sticking
    "Turn off the television sets and eradicate the slander that says a black youth with a book is acting white." - Barack Obama
    Oct 2001
    87 Accord EX , 5spd , Manual
    check your pads and clean them ( sand them ) and clean the rotors ! you can use some anti squeel stuff !
    MIKE
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Like the others said, check the pad thickness, if that's good, then just spray some brake cleaner on it.
    DX User rutterg's Avatar
    Oct 2002
    1980 Accord 3d, 1985 Jazz, 1991 Civic Shuttle, 1991 Saab 900i 2.1-16V
    Netherlands
    I had the same thing when i just got my car. i cleant the brakepads, caliper and disc with brake cleaner. no improvement. it turned out that the piston was stuck, i assume because the car had stood still for a while. worked on the piston so it moved in and out again, assembeld everything back and the squeeling was gone.
    Jun 2002
    So I took apart the caliper yesterday, and it appears the pad was pretty low... there's roughly 3mm of material left... what was making the noise was a "clip" dealie on the top of the outer pad... imagine a "u-shaped" metal part, with the top of one of the legs rubbing against the disk, and the other top being secured to the pad. I assume that tab is there to let the driver know that his brakes are coming to an end... So, long story short, I don't think it's a big deal, just gotta switch them pads soon...
    While I've got a thread open - any advice as to how to push the brake piston out once I've got a thicker brake pad in there? I tried to mess with it with a c-clamp, and it seemed to be a bitch... any know-how tips?
    Thanks,
    2Fast4U
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Yes, you are right with the metal indicator on the pads. Change the pads soon if not it'll make score marks on your rotors and you've to turn or get new rotors.
    Yes, just use a c-clamp to push back the piston. You can use your brake pads on top of the piston and then use the clamp to push the pistons back so you won't harm the piston. You might want to open the bleed bolt a little to let the brake fluid out.
  1. Engine revs high when clutch pressed
    By phnipnip in forum 3geez Accords
    Last Post: 10-24-2012, 07:20 AM
  2. Constant Squeal
    By halxi in forum 3geez Accords
    Last Post: 06-09-2005, 07:33 PM
  3. Quick help please anti-squeal pads
    By A20A1 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-20-2005, 10:53 PM
  4. Rotors squeal in reverse only.
    By Dibbs in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-29-2004, 08:07 PM
  5. TB chirp/squeal
    By CASH24 in forum 3geez Accords
    Last Post: 04-21-2003, 09:05 PM
