My girlfriend's 1986 LXI (EFI A20A4) hatchback is losing spark somewhere. The fuel system is fine, but it loses power only SOMETIMES. I've felt the same symptom on other cars, and I'm pretty sure that there is weak or lost spark somewhere.
The thing sort of stutters/misses a little at idle until it gets really warmed up (1/2 hour or so), but at certain RPM's (and only SOMETIMES), it SERIOUSLY loses power.
So I'm thinking there's a spark leak somewhere in the coil or wires or something.
Anyway, has anyone had problems with the ignition system on these EFI's? If so, what do you think I should test other than plugs (they're fine), wires (I think they're fine but I will look closer and check w/ ohmeter) and coil?
Last time I checked the advance it seemed to be working right, and I THINK the timing is right because I checked it a few months ago and it was OK. BUT I think that it might not advance/retard smoothly sometimes.
There is some red dust in the cap so I think the bearings are going bad.
Anyway, what do you all think I should do? I don't want to buy a new distr. I'll probably buy junkyard parts & rebuild w/ whatever is best from 2 distributors.
