Results 1 to 3 of 3
Thread: HELP! 88 Honda Accord Idling Very High
    DX User HaskellBeauty09's Avatar
    Sep 2013
    88 Honda Accord DX Hatchback
    Hillsdale, NY
    I recently lowered the idle (the screw under the carburetor) as much as it would go. It was idling at 2500 RPM's and when I lowered it to around 1200 but recently it has spiked back up to 2500 and I have no idea how to fix it. I cleaned the carburetor and put a cleaner into the fuel tank to hopefully help out a little bit. I can't even begin to wonder what it might be I did recently change out the fuel pump because it wasn't the right size (previous owner had installed it). Any possible ideas would be so very helpful. Thank you.
    Re: HELP! 88 Honda Accord Idling Very High
    Check for a vacuum leak first. Also make sure that your throttle cable is not binding.
    Nov 2006
    88 DX 5spd sedan 176Kmiles, 1 owner, stock. (Sold 10/18)
    With the engine fully warmed up, take the air cleaner cover off and check that the Choke Butterfly is fully open, straight up.
  1. Idling very high, especially when hot
    By Austin's 86 LX in forum Carburetor Tech
    Last Post: 09-01-2011, 08:56 AM
  2. 87 honda accord dx a20a idleing high
    By kotty4643 in forum 3geez Accords
    Last Post: 02-10-2011, 09:13 AM
  3. 3g idling in high RPM ?????
    By rfiks in forum Carburetor Tech
    Last Post: 07-19-2009, 09:00 PM
  4. 87 Honda Accord idling/stalling issues
    By aeongap in forum 3geez Accords
    Last Post: 08-19-2005, 03:58 AM
  5. Carb is idling too high
    By 82h in forum Carburetor Tech
    Last Post: 11-02-2004, 08:57 AM
