Results 1 to 8 of 8
Thread: Advancing Cam A Tooth?
    1989 Honda Accord LXi
    Orlando, FL
    Ive seen some people posting say advancing cam a tooth will improve performance. If this is true, is it due to higher compression. Also if cam is advanced should the distributer be set to stock postion or should it be advanced also or retarded. Also would this setup work with a aftermarket performace cam or would u have to retain stock settings.
    Thank for the help.
    Mike
    [email protected]
    I read in car craft once that advancing your cam moves the power band down a few hundred rpms whereas retarding it raises it but it would seem the other way around to me b/c at higher rpms the air should be injested sooner to make up for momentum
    anybody care to clarify?
    AZmike's Avatar
    Tucson, Arizona
    I recently replaced my timing belt and ended up with my valves one tooth advanced. It started up really fast but it ran raelly rough above 2300 rpm. I wouldn't recommend it.
    Mike
    1988starter
    Guest
    I would only recomend it if you have a modified cam
    SEi User myaccord7's Avatar
    89 honda accord LX
    Quincy,IL
    i have a modified cam. an openloop. can i asvance it of retard it? what will it do and whice is better?
    zach
    AZmike's Avatar
    Tucson, Arizona
    You'd need an adjustable cam gear, which is not commercially available for our cars (I think). One tooth either direction is too much.
    Mike
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I would just get different performance parts until you find out for sure. Does anyone know if those underdrive pulleys add hp to the car? The ones from openloop.
    88 Lxi/ 5spd
    Tennessee
    One tooth advanced on my car with a modified colt cam worked wonders. Made my 0-60 probably decrease by a whole sec....anywayz you can really tell a difference in traffic at low rpms. I'm not sure how the stock cam would respond. By the way one tooth is like ~8-9 degrees.....which most aftermarket gears go to 10 so is a little on the extreme side but I've noticed I can't tell the difference in the powerband until I change it by 3-4 degrees anyways. Caution....my butt might not be as senitive as yours.
    In the end...it doesn't even matter.
    88 Lxi, 5spd swap w/ Aasco 8lb flywheel/Cai,AccelCoil,NologyWires,SilverstoneSparks/DC421,ColtCam,Remachined Head&Tb...NitrousWorks 40shot
  1. Advancing Timing
    By igarut5410 in forum EFI Tech
    Last Post: 04-05-2008, 10:57 PM
  2. Advancing Timing
    By bushbean in forum Carburetor Tech
    Last Post: 04-14-2007, 05:01 PM
  3. advancing timeing...
    By aussiegen3 in forum Performance
    Last Post: 01-20-2004, 10:39 AM
  4. advancing timing???? HELP!!!
    By cdscowboy in forum 3geez Accords
    Last Post: 09-20-2003, 08:27 PM
  5. advancing the cam timing?
    By Mantis88LX in forum Performance
    Last Post: 06-15-2003, 08:37 PM
