A week ago my car started to drip oil in my driveway. Its a huge quantity below the front crankshaft sealing.
Bought the sealing (and the timing belt), since I was going to open that area of the motor.
After removing the pulley and the plastic cover of the timing belt I noticed that almost everything there was wet with engine oil.
Proceeded to change the sealing and the timing belt. Put everything together and... the leak is still there.
Is it possible the oil pump is leaking? Or what can it be another source of oil? I checked the oil pan but everything around is wet with oil, so there is no visual indication of where the leak might be. Any thoughts?
