Results 1 to 7 of 7
Thread: Help, my car chokes
    89cordlx's Avatar
    Black 1989 LX-I Coupe and 2000 EX V6 coupe
    Westerville, Ohio
    Help, my car chokes
    OK, when I press the gas to go my car studders, whats the problem? It only really happens when the car is warm. Also, my gas pedel seems to be kinda loose, how do I fix that?
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Change the fuel filters and a tune up if it hasn't been done in a long time. For the gas pedal, stick your head down there and see which part is actually lose.
    Oct 2001
    87 Accord EX , 5spd , Manual
    when did that start to happen ! and what did you replaced ?
    MIKE
    89cordlx's Avatar
    Westerville, Ohio
    Nothing has been changed accept I have an accel coil. Maybe it is that I haven't regaped the spark plugs. A tune up is probably in order anyways, I just hope it's notthing to major, Monroe totally screws you over with labour.
    Check my cardomain for sale items! Cardomain
    Oct 2001
    try new plugs then wires !
    MIKE
    87accordlxph's Avatar
    Carbed 1987 Honda Accord LX & Black 4th gen Accord (91)
    Petrolia, Ontario Canada
    Your plug wires may be in the wrong spark plug order.
    Mike's Clean Cnd A20A2 5 spd Champaigne Beige Sedan Accord, Eh!
    B-Day: 07/87 in Alliston, ON Canada
    The best mods are mods that can be modded over and over again.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Check for loose spark plugs and wires... change the fuel filters.
    other things that may cause hesitation:
    - Broken Vacuum line
    - Ignition timing off
    - Old spark plug.
  1. noob question about chokes
    By train in forum Carburetor Tech
    Last Post: 10-25-2004, 05:46 PM
  2. weber carbs and chokes ?
    By seancornelis in forum Carburetor Tech
    Last Post: 12-08-2003, 12:21 PM
  3. Help. Engine chokes at 5k
    By jteuton in forum 3geez Accords
    Last Post: 06-22-2002, 01:58 PM
