Results 1 to 5 of 5
Thread: i think my distributor is fried
    shepherd79's Avatar
    Falling Waters, WV USA
    ok,
    my car starting to act funny again. it won't hold RPM. it would go up and down all the time.
    a few month ago i had to replace my distributor because it wouldn't hold any RPM.
    So what can be the problem with my distributor. Why am i frying them?
    you don't think it is because of the accel coil?
    well, any help would help a lot.
    thanks guys.
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    if you mean that your igniter gets fried.......normally....the main culprit for igniter failure is Heat......hows the operating temp of your engine?
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    ...it won't hold RPM...
    which RPM, idle or 3000 ?
    If there is something fishy with distributor, it might be the high voltage side, i.e. cup and rotor. My cup didn't last 3 month either, noticed fine cracks inside...
    shepherd79's Avatar
    well, i should told mention this, i don't have choke on my car or any vacuum stuff.
    i just got home, and before i pulled into my subdevision my car started to adle at 2000rpm(i had to turn it to make it run half way disent), so i turn it down and it fine now. i have no fucking clue what happed. may be something inside distributor got stuck or something.
    anyway, i am gonna switch to Toyo distributor, Hitachi sucks.
    1988starter
    Guest
    good luck and make sure to get the timing light out when replacing it. God I love my timing light
  1. is my ecu fried ? need help !!
    By 247shuer247 in forum 3geez Accords
    Last Post: 11-12-2012, 09:36 AM
  2. main relay fried
    By xxdecompilerxx in forum EFI Tech
    Last Post: 09-16-2009, 07:45 PM
  3. Fried power lock unit.
    By LXrocks in forum 3geez Accords
    Last Post: 12-08-2008, 09:39 AM
  4. Fried rings, where to buy rebuild?
    By halxi in forum Performance
    Last Post: 01-29-2007, 09:49 PM
  5. Fried the alternator
    By powderkey2 in forum Interior & Exterior Care
    Last Post: 03-11-2005, 10:43 AM
