My girlfriend's 86 LXI (which I'm having trouble with) blows only luke-warm.
The temp gauge reads in the middle, but w/the heater on the hot setting, it's not blowing very hot.
The heater cable to the valve is busted, so I manually set the valve to the hot position under the hood. I pulled it UP as far as it would go, which I know is hot, and I really jerked it. I don't think it's at half-way or anything.
And after like 40 minutes of driving it starts to get hot, but it takes that long.
I put a cheap aftermarket thermostat in the thing when I changed the radiator a couple months ago. Is it maybe stuck open?
And, in general, does the coolant circulate between the engine and the heater core ALL the time or only after the thermostat opens? I've always wondered about this. It's ALL the time, right?
If you guys think I have a bad thermostat, what kind would you recommend?
ALSO, the car runs shitty for like 1/2 an hour, but as it starts to blow hotter, the idle smooths out. I think that whatever makes the car go on fast idle doesn't work long enough because the idle drops to 900 after only a couple minutes, but it stutters at idle until like 30 minutes of driving.
You think it's just because the engine doesn't reach operating temp in freezing-ass Chicago since the t-stat is maybe always open and the RPM's don't stay high enough...???
Could there be another reason for being luke-warm (the coolant has been full for a while -- it's not leaking any anywhere)/
