Results 1 to 8 of 8
Thread: automatic transmission question
    Oct 2013
    1988 Honda Accord Lx
    Northern California
    So I have noticed that sometimes when I shift the car from park to reverse, it clunks sort of or like bumps. Its worst when the car is cold. Does anyone have any idea of what could be wrong and how much it would cost to fix it?
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    Re: automatic transmission question
    Do you park on a incline?
    Try doing a transmission fluid swap make sure to use OEM fluid only.
    Mar 2003
    2004 Acura TL
    Arkansas
    It doesn't sound like a ratcheting sound, does it?
    Oct 2013
    Northern California
    Nope
    Oct 2013
    Northern California
    Ok ill try that thanks!
    Mine have done this...still do. I Think its a halfshaft pitching out a little and loose/ worn mounts amplify the issue. Sometimes halfshats may not be strongkt seated because the lockring is poorly fitted, worn or, aftermarket
    LX User niles's Avatar
    Oct 2009
    87 LXi Hatch
    Portland
    I believe mine does the same thing you are talking about. I don't worry too much, I change my fluid twice a year and it shifts OK. When going from reverse to drive, or drive to reverse, I make sure to give the transmission time to change modes. Think of it as an old athlete, they perform pretty well but can be sluggish sometimes.
    I have the same clunk on my lude going from P to R and R to N and back from N to R and R to P. D to N and vice versa didn't make a noise. Not sure whats going on either.
  1. Automatic transmission question.
    By ZiggyxFresh in forum 3geez Accords
    Last Post: 03-16-2005, 05:06 PM
  2. Automatic Transmission
    By swiff in forum 3geez Accords
    Last Post: 04-20-2004, 11:21 AM
  3. Automatic Transmission
    Last Post: 03-26-2004, 10:14 PM
  4. Anyone ever take apart an Automatic transmission?
    By Gregg86DX in forum 3geez Accords
    Last Post: 02-03-2004, 12:14 PM
  5. automatic transmission question
    By oldskooln in forum 3geez Accords
    Last Post: 06-27-2003, 09:44 PM
