Results 1 to 20 of 20
Thread: finally the clutch how to !
    Oct 2001
    87 Accord EX , 5spd , Manual
    Talking finally the clutch how to !
    finally after over 2 week of working on it i wrote this how to with the help of a lot people who are mentioned in the how to !
    http://members.fortunecity.com/accor...lutchhowto.htm
    i am posting that here so the expert people could review it and comment here ! any useful tips from self experience are welcomed .
    enjoy !
    MIKE
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Why is the new shift rod pin necessary?
    "1. 8mm > 22 mm sockets and wrenches"
    the axle is 32 mm
    I used 19, 17, 14, 12, 10 and maybe 13 sockets and 17, 14, 12, and 10 wrenches
    "5. a small handy pump to pump in new tranny oil ."
    A funnel with a hose works from above and is probably faster and cheaper
    "NOTE: When removing the speedometer cable from the transmission, it is not necessary to remove the entire cable holder. Remove the end boot (gear holder seal), the cable retaining clip and then pull the cable out of the holder. In no way should you disturb the holder, unless it is absolutely necessary."
    Why? I just pulled the holder and left the PS system and speedo cable alone. Is there a good reason not to do this?
    List the spring washer that should be replaced in the required parts list too
    Mike
    Jul 2002
    Twin Weber DCOE Powered 88 Honda Accord LX
    Columbus, OH
    "A funnel with a hose works from above and is probably faster and cheaper"
    -Yeah, that's how I replace the transmission oil too. I bought a nice funnel with a hose attachment at Wal-Mart for $5. I use it a lot.
    Mike Clark
    Oct 2001
    i really appreciate these replies i'll add all the comments !
    about the speedo holder thing i didn't write that but that's what written in the chilton's manual !
    but i think removing the holder will be easier ! so i 'll retype it !
    thanx guys !
    MIKE
    Oct 2001
    what spring washer ! ?
    MIKE
    Aug 2001
    1988 Accord LX-i (RIP)
    Another option for adding tranny fluid: Your mom's turkey baster... (really cheap)
    (let our minds not get perverse all just yet... )
    This useless space for sale, please inquire at the front desk.
    Oct 2002
    1987 accord lx
    Chicago
    When I had to fill my tranny fluid, I was too lazy and cheap to go out to the store and get any of those things.
    So I used my little oil-can -- you know, the oiler that you squeeze to put a little oil on parts.
    I know, it's like the stupidest way to do it. It'll take you 1/2 hour.
    But it gives your hand a good workout.
    This is for those of you who have one of these and nothing else.
    Oct 2001
    :lol ! man that's torchure !
    MIKE
    Oct 2001
    BTW what do you guy think of the how to ! ??? is good enough to be put in the How to ' section ! ???
    MIKE
    Jul 2002
    Columbus, OH
    "BTW what do you guy think of the how to ! ??? is good enough to be put in the How to ' section ! ???"
    -Absolutely! It's a definite improvement over what the manuals offer because it is more detailed, filled with recommendations from personal experience and it offers more pictures.
    In my opinion, it belongs in the How-To section.
    Mike Clark
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    MIKE
    The one that your instructions recommend replacing on the bolt that holds the release fork in place.
    I didn't follow the instructions and reused my old one because I didn't want to ride my bike 12 miles to get a $2 part that probably won't end up making a difference.
    Mike
    Oct 2001
    yeah thanx Mike !
    i 'll put it in the parts
    and i know a lot of these stuff are not necessary but you don't want to drop the tranny again for 2 bux ! i 'll write beside it " recommended "
    MIKE
    Oct 2001
    any other comments on the how to ! last call !
    MIKE
    89 Accord LX Coupe
    Vernon BC CANADA
    Heres a question..
    Why havent they made cv's easier to take out ...???????
    i cant remember whcih car it was...i think a subaru but the one end bolted up to the tranny end cup...
    so to remove all you needed to do was reomve the bolts and the .....
    wait actually the older suubs have spring pins holding them on.....
    It must be a cospiracy between all makers of cars to make them harder to remove so you break stuff and have to buy it from them...
    just a thought...like why couldnt they make them bolt up to a plate were it enters the tranny...so then you wont have to drain the fluid and you can save like half the time on pulling the tranny out...
    Ben
    Nov 2002
    1988 4Dr Accord LX-Burgandy
    Winnipeg, Canada
    Post another way to do it
    A friend was telling me that he changed a clutch for one of his nieces last week. It was on a Civic but I assume it would be close enough to apply to an Accord. He did the transmission removal a little differently. He rigged up a bar over the engine from front to back to hold it in place from above and then used chains and a chain hoist from above to hold the transmission while he slid it over instead of supporting it with a jack from underneath. He said it worked well since he was doing this by himself. It gave him more room to work underneath and supported the transmission well when he was reinstalling it.
    Randy
    Oct 2002
    1987 accord lx
    Chicago
    I actually used ropes to keep my trans up while I maneuvered it into place. I had the thing on a phone book on my jack, but I didn't really have help, and so this wasn't enough.
    The goddamn trans on 3g's really won't balance well on a flat surface (like on a book on top of a jack).
    So I rigged ropes to it -- just cheapo nylon rope that's like 1/4" thick about -- and tied them to various things on the car. I roped one underneath, tied to around where the hood-latch is, under the trans, and then roped it around the right-side mirror. Then I roped another one underneath and rigged it to the left-side mirror.
    Oh, actually, I think I put the rope through some of the bolt-holes on the top of the trans-axle.
    But I basically would pull up a little bit on one rope to get one side higher, then tie it off, then maneuver the jack to pick it up a little bit, then pull up the other side w/other rope...
    I did this for maybe 1/2 hour of getting the thing propped w/ropes & jack so it was as close as possible to being perfectly lined up, and then I pushed it into place from underneath on my creaper.
    The ropes helped A LOT! They helped me keep it steady and balanced, and also provided insurance so it wouldn't fall off the jack and crush me!
    And I just roped it to stuff on the car itself -- didn't need hoist or anything like that.
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    Excellent job, Mike! I'll definitely be using this when/if my clutch ever decides to die, heh
    -Jared
    Oct 2001
    oldsub86 : i understand your idea of using a hoist ! but how many of us really have a hoist and a chain ! and as you can see i made this how to for all people not for pro's only !
    Jareds 89 LX-i : thanx !
    anyway i am putting it in the how to and i can add anything later if anybody has a problem following it !
    MIKE
    2.0Si User Grant2k's Avatar
    Jul 2002
    Mike, exellent job. I am gonne be reffering to this a lot this coming winter. although, as good a job as you did, i still do not look foward to doing it.
    Oct 2001
    no body looks forward for a clutch job ! so expensive parts !
    MIKE
  1. Finally doing my clutch
    By 79cord in forum 2geez Tech & Performance
    Last Post: 05-05-2008, 03:30 PM
  2. Finally oh finally i bought my stereo lol
    By Crazybird in forum Interior & Exterior Care
    Last Post: 10-25-2006, 06:21 PM
  3. 89 prelude clutch pedal or cLuTcH problem!?!
    By myaccord7 in forum Classic Preludes
    Last Post: 10-14-2006, 10:45 AM
  4. Replies: 5
    Last Post: 12-13-2005, 02:33 AM
  5. stage 1 clutch from Clutch Master or Nippon
    By MarioBurke in forum Performance
    Last Post: 07-11-2003, 11:25 PM
