Results 1 to 14 of 14
Thread: Timing Advance
    LXi User 1989se-i's Avatar
    89 Accord SE-i Coupe
    Jokelahoma
    Timing Advance
    I wanna move my power to the low-end. Will advancing the time about 5 degrees accomplish this?
    How do i advance the timing? *embarassed*
    Performance Modz: Short Ram Air Intake, Custom Exhaust w/o Cat & Resonator, Cherry Bomb Turbo Muffler, Accel Coil, Removed AC
    Other Modz: Clear Blinkers, Purple Calipers, Accord Emblem On Dash, Winking Headlights
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    To advance the timing, LOOSEN the 3 distributor bolts until you can turn the distributor. Set up your timing light as per instructions. Start engine. Point timing light, see where your timing is at stock. Then turn the distributor towards the firewall. This will advance your timing. How many degrees you might want, I'm not sure.
    You can advance the distributor without a timing gun by marking the distributor and the flange first, then advancing it until you hear knocking, then back down a tad.
    hth
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    You'll also need to run higher octane gas. 91/93 is good.
    Jokelahoma
    Cool, thanks guys
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Originally posted by 1989se-i
    Cool, thanks guys
    There's just ONE GUY
    You're welcome.
    Oct 2001
    87 Accord EX , 5spd , Manual
    now we are 2 !!!
    :lol
    MIKE
    Jokelahoma
    I see :p
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Check for knocking at high revs too. Even if the idle is good when the distributor advances itself for high revs you may get some knocking. I'm pretty sure, but not certain. Someone please correct me if I'm spreading lies.
    Mike
    1988starter
    Guest
    dn't forget to disconect the vacume advance. Also buy a timing gun they are with the 50 bucks or so for a good one.
    shepherd79's Avatar
    Falling Waters, WV USA
    oh i don't wanna be an ass but you are all wrong.
    advencing timing on distributor will not move power to low end. it will make spark plug work better at higher RPM.
    to make your car wrok better at low RPM you will have to get adjustible cam gear. than you can advence it by +3(i think it is max) and it should shift your power band into lower RPM. But remmeber, you will not be able to get performance out of high rpm.
    good luck.
    87 Lxi Hatch<-Blown Up!! 96 civic coupe
    Hot, Sweaty Florida
    If i advance my timeing wont it give better lowend power?? ANd when you retard the timing you get more @ topend!!! Isnt this correct??? Some one that knows please let me know if im right!!!
    Cold Air intake, Apexi N1 turbomuffler w/2.25 piping, H22 injectors,gutted cat, Dc sport header, accel coil, MSD ignition, Dropzone coilovers
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Yes, it doesn't move your powerband but it does give you more peep at low end if you advance the timing a few degrees and vice versa (for highway perhaps, or dragging). Cheap torque but you must pump higher octane gas.
    shepherd79's Avatar
    make sure you people understand that timing i was talking about is not distributor timing. it is the cam gear timing.
    Oct 2001
    Alex : i think they are talking about ignition timing because it's easy to advance !
    MIKE
  1. advance my timing for mpg?
    By rocketman in forum 3geez Accords
    Last Post: 04-22-2011, 05:22 PM
  2. how can i advance my timing!
    By salgmz in forum EFI Tech
    Last Post: 03-18-2007, 10:11 PM
  3. timing will not advance far enough!!!
    By johnwc723 in forum 3geez Accords
    Last Post: 02-24-2004, 06:19 PM
  4. How to advance timing II
    By LX-biker in forum 3geez Accords
    Last Post: 07-22-2002, 07:25 PM
  5. how do i advance timing
    Last Post: 07-15-2002, 03:20 PM
