So here is a little concept I want to throw at you guys. Rather than replacing the front upper control arm, how about we make the ball joint assembly adjustable for camber. Here is what I came up with, in the photo shows the camber adjuster with two slotted holes. The slotted holes are 1/4" longer than the prelude holes to add another 1 degree of adjustment. The spherical bearing would mount inside the hole, with a snap ring retainer. This allows for replacement. The bolt/pin assebly would be machined to match the thread pitch and taper of the stock ball joint to mount into the upper control arm. Each set of these would be around $150 + shipping. They would include both sides, two spherical ball bearings, snap rings, new hard ware, and ball joint pin and castle nut.
![Click image for larger version.
Name: Camber Adjuster.jpg
ID: 5609](https://www.3geez.com/forum/attachment.php?s=9507c5dd566bd6b6d5f6a0afd5a18a3d&attachmentid=5609&d=1588037754&thumb=1)
