Results 1 to 18 of 18
Thread: runnig to rich??
    LX User Experimental_Honda's Avatar
    Jul 2002
    94 accord lx, 88 sold
    ky
    runnig to rich??
    so my car keeps stalling, it starts up fine but when im at lights it dies unless i rev it to keep the rmp's up.....im thinkig its running rich and my carb needs to be tuned......any 1 have any insite???
    Jul 2002
    ky
    oh yeah it happends after it runs for an hour or so......when the car is motor is nice and warm, when its cold it works fine
    1988starter
    Guest
    I had that problem now I use lucas oil additive and it keeps the oil thicker fixed that problem.
    10/Honda/Ridgeline
    NJ
    Its ur vaccum. Check the bleed valves in the air box. Their vaccum lines prevent ur ca from stalling. also, check to see if the idle knob unscrewed. I had the same problem when i had the carb. I boosted up my idle knob and tightened the AJC a lil to keep the idle low. Also check ur throttle cable tension.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Make sure it's not an overheating problem first, so check your coolant level... also check your oil level and avoid using oil additives when possible, instead swithc the oil to a heavier weight... so if it was 10w20 go to 10w 30
    Banned
    Oct 2002
    2000 Ford Focus SE 5spd
    Spencer, MA a bit outside of Worcester
    A20A1 is probably right... not just that stuff but check ur thermostat also... it could bee broken and causing ur car to stall and over heat.... that happened to mine a bit ago
    Jul 2002
    ky
    thanks for the help we are gonna work on it tomarrow....i will tell you all what is was when i find out
    Oct 2001
    87 Accord EX , 5spd , Manual
    i don't think running rich will make your car die ! it will give bad MPG and hesitation !
    or it will stall all the time !
    MIKE
    Jul 2002
    ky
    so i found out what was going on, it was running rich. last time i got a fill up i got a full tank of bad gas. my boy that i bought the car from used my car for a few days and fucked around with the carb. so now thati have good gas with some nos booster in it its running way rich.....i hope.....i still ahve not fixed it yet so i may be wrong but we will see
    A20A1's Avatar
    Sep 2001
    Why did you use octane booster?
    High Octane makes it harder to ignite the fuel.
    So if you are running rich you are increasing the chance that your car won't run.
    Rich mixture is hard to burn, just like higher octane.
    and if you don't have your ignition timing set right, you'll get bad performance/gasmilage.
    Do you know what he did to the carb or tried to do... it's hard to mess up the carb without knowing where the screws are and how to adjust them. the only screws that are easy to get to, that will change fuel consumtion aside from a high idle is the float bowl setting. The A/F ratio screw is sealed off... you'd have to remove a lot of things to get to it.
    Oct 2001
    is it easy to adjust float bowl ?
    MIKE
    A20A1's Avatar
    Sep 2001
    MIKE
    yes, you just take off the air box.
    Oct 2001
    thanx Mike ! you're the man !
    but when do i need to adjust it ! ( symptoms )
    MIKE
    Jul 2002
    ky
    i have no clue what he did? but his cus fixed it.....now my carb is running better than it ever has! it have alot more get up then i used to
    1986 Accord DX (all stock) - 5 spd - Silver
    Cheshire, CT
    Here's a question about tweaking the fuel mixture: Is it okay to do it myself as outlined by some of you guys? I thought one was not supposed to do it without a propane kit? And does it affect emissions stuff?
    okay -- so that was two questions :-)
    A20A1's Avatar
    Sep 2001
    It will effect emissions... anytime you adjust the Air/Fuel ratio to a rich mixture you start polluting more.
    Don't adjust the float screw on a whim... as you see in the pic below the float screw has 2 O-Rings... these O-Rings are easily broken... even when brand new.
    If they break... you'll get a large fuel leak.
    A20A1's Avatar
    Sep 2001
    This is how to remove the float screw... if you happen to break an O-Ring before reading this post.
    Oct 2001
    thanx a lot Mike ! :super:
    MIKE
  1. I'm not rich, but the car is.
    By Krusty55 in forum 3geez Accords
    Last Post: 11-10-2007, 12:16 PM
  2. too rich???
    By gfrg88 in forum EFI Tech
    Last Post: 02-12-2007, 08:45 PM
  3. I'm RICH!!!
    By jigga89SEi in forum Classic Honda Pics & Videos
    Last Post: 05-25-2005, 07:45 AM
  4. Running Rich
    By 1987HondaAccord in forum EFI Tech
    Last Post: 01-10-2003, 01:35 PM
  5. Running rich in the wet?
    By 89AccordNate in forum 3geez Accords
    Last Post: 12-12-2002, 08:04 PM
