Results 1 to 6 of 6
Thread: how to remove front bumper molding to replace horn?
    May 2012
    central Ohio
    I really need to replace the horn. Driving around without a working horn is a safety hazard. As I understand it, the front bumper molding must be removed since the horn(s) is(are) located behind it. Removing the molding seems more complicated than I initially thought. Some of the fasteners (between the head lights) are fully accessible with the hood open but I see that other fasteners are located under panel under the headlights. See the photos; key points are marked in red. Do I need to remove headlights in order to get the bumper moldings off? Do I need to remove side marker lights?
ID:	5611   Click image for larger version.
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    Re: how to remove front bumper molding to replace horn?
    STOP!! dont remove all those screws remove the two front turn signals behind those should be 2 bolts on each side then theres a few bolts on the bottom side of the bumper and off it comes.
    May 2012
    central Ohio
    OK, thanks! I had not started on this yet so I'm glad I posted the question here before attempting to remove it.
    iirc you should be able to access the horns just from removing the covers under the bumper lights without having to remove the bumper
    May 2012
    central Ohio
    Ah, thanks for that tip. I'll try that approach first. If it works, it will save time and effort. If I don't see that horns there, then I'll know I need to proceed with the bumper removal.
    "Access" is a long ways from "able to comfortably and accurately replace". Remove the bumper: four bolts, six screws. Bam.
  1. How to remove metal strip/panel above rear bumper molding?
    By derolph in forum Interior & Exterior Care
    Last Post: 01-19-2013, 04:24 PM
  2. [Appearance] Install Remove Front Bumper
    By Knowledge Base Admin in forum How To
    Last Post: 03-17-2006, 12:39 AM
  3. how to remove front bumper?
    Last Post: 09-04-2002, 07:34 PM
