Results 1 to 12 of 12
Thread: Retaining water....
    LX User 3rdGenMartyr's Avatar
    Jun 2002
    89 lxi sedan with 300k on the motor
    Bonne Terre, Missouri
    Retaining water....
    Does anyone, or has anyone had a problem with a leaky deck lid or seal? I've noticed that when it rains hard, i get water in my trunk, and its emanating from the driver's side. I've also found water in the break light assembly on the same side, and since the outside of the assembly is fine, I'm going to assume it got there from underneath the deck lid. Anyone who could share some insight to this problem, would be greatly appreciated.
    can i loan you some mileage, i got enough to go around
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Jun 2002
    1989 LX-i
    San Jose, CA / SLC, Utah
    My problem is sometimes my sunroof leaks...
    -Seabass
    SEi User MoonScryer's Avatar
    1986 Prelude 2.0si turbo - 1990 Integra moutain carver - 1993 Nissan 300ZXTT w/ more power than god
    Atlanta, GA
    New seal on the sunroof, and clean the drains out....only thing that can be done there.
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Not to get of subject but when I read the title I thought," Is it that time of the month?":lol
    SEi User toastyghost's Avatar
    Mar 2002
    a 93 z34 that's getting parted out, an 86 accord lx that now lives in a j/y, and a 90 camry le that the state no longer allows me to drive. soon to be replaced with an aprilia rs50 or a derbi gpr.
    Harrisonburg VA
    Someone has too much salt in their diet...
    ~<+045+ygH05+>~
    Banned
    Oct 2002
    2000 Ford Focus SE 5spd
    Spencer, MA a bit outside of Worcester
    yeah take some laxative that way u can get rid of some water inside...
    Jun 2002
    i figured the title would get someones attention
    LXi User 87Hybrid's Avatar
    2002 Chevrolet Silverado, 87 Hybrid Civic, 76 Chevy Blazer, 2000 Jetta, 1985 Civic sedan
    Battle Ground WA.
    There are a couple of possibilities.
    Possibility #1
    The most likely problem is just the seal around the tail light where it bolts to the bodythe light housing may be loose ot he seal broken. when it rains the water runs down the roofline and into the galey around the trunk seal which routes it to the back to drain behind the bumper. When the seal around the light is loose and not getting a good seal the water will go into the trunk and even run into the tail light housing its self. Solution remove tail light clean the surface where it bolts to the car and replace the seal on the tail light if needed.
    possibility #2
    If your car has ever been rear ended and repaired there is a possibility that the sealer/calking that is used at the factory to seal the pinch joints near the back of the trunk water galley may have been lifted and allowing water to pass into the trunk. I found this type of leak in mine by crawling in the trunk with a flashlight and having my wife spray water from the hose around the edge of the trunk. To fix this I just used windshield adheasive but most any sealer will work. Make sure to clean the leaking area and blow it dry with either compressed air or a heat gun, you can use a hair dryer as well but it will take a longer time to get it dry. then apply the sealer or calking liberly, trying to push some into the joint with a popsicle stick, to the area and let dry before closing the trunk
    "AAHHH Teamsters, If only I could be as lazy and surley as a Teamster." Quote by Homer Simpson
    SEi User Y3G's Avatar
    05 G6 for now
    Niagara Falls Ontario
    87hybrid you da man thanks for the advice!
    Jun 2002
    i found a rusty spot inbetwwe the quarter drop off where it meets the deck lid and the seal to the truck, i tried some silicone, lets cross our fingers when it rains..... lol
    05 G6 for now
    I REALLY HATE WATER
  1. Replies: 0
    Last Post: 11-08-2010, 11:02 AM
  2. Balljoint retaining clip (circlip?)
    By T-Funk in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-09-2006, 01:42 PM
  3. retaining carb heat function for the winter with the scoop
    By lostforawhile in forum Carburetor Tech
    Last Post: 11-12-2005, 04:58 PM
  4. Replies: 16
    Last Post: 11-05-2004, 09:21 AM
  5. caliper retaining bolts
    By SLCPUNK in forum 3geez Accords
    Last Post: 11-23-2002, 01:36 AM
