Results 1 to 3 of 3
Thread: 16x6.5 rims with 55mm Wheel Offset
    LX User niles's Avatar
    Oct 2009
    87 LXi Hatch
    Everyone with larger rims: will a 16 inch rim with a 55mm offset rub on my inner fender?
    I fianlly found the closest match to my dream rims, with the correct bolt pattern, but larger offset. I don't think rolling the fenders will be necessary but will turning too tight make the tire rub on the inside?
    aluminum-alloy-wheel-rim-16x65-4x100-bolt-pattern
    DX User NastyNancy's Avatar
    Sep 2013
    1988 LX-i Furr Dur
    Re: 16x6.5 rims with 55mm Wheel Offset
    Ooo it might rub on the inside up front yeah. Here's a comparo from my current set up to those wheels -> Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit.
    In my opinion they'll stick in too far too, but that's just me.
    "You can't ride low if you ride high"
    Oct 2009
    87 LXi Hatch
    I was afraid of that, and I don't really like the idea of using spacers. I will keep looking up part numbers, maybe go with some of the aftermarket rims if I can't find anything.
  1. Wheel Offset
    By SjNoob in forum 1geez Tech & Performance
    Last Post: 05-13-2013, 03:26 PM
  2. Wheel offset
    By mix4 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-09-2007, 11:14 PM
  3. will 4 by 108 rims offset of +42 mm fit
    By billyaccord in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-08-2004, 01:36 PM
  4. Wheel offset.
    By Hash_man_Se_i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-07-2004, 04:50 PM
  5. How can you tell the offset..etc... on rims
    By NeubJ in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-01-2003, 12:25 AM
