Hello everyone,
I'm the original owner of a 1989 Honda Accord SE-i Coupe. The car has seen limited use over the years and now has less than 47,000 km on the clock. The car is quite solid but some rust is present in the usual areas. It was rust proofed when it was new which worked reasonably well despite the rust that has appeared in the last few years. Unfortunately, it needs a fair amount of mechanical work. The lack of use and the insane amount of salt and sand used around here during the winter has taken it's toll. In the last 12 years, the brakes had failed on me four times due to rusting brake lines. Quite an unpleasant experience as I'm sure you can imagine.
Les.
