Results 1 to 12 of 12
Thread: gas door latch release inoperative
    May 2012
    central Ohio
    About 3 years ago (winter of 2010/11), my 88 Accord was parked outdoors during major storm (freezing rain) and the gas door would not open due to ice. The entire space behind the door was literally a block of ice. My son was driving the car at that time and apparently used too much force when trying to pull the interior handle for the gas door release and, since the latch could not move, the latch cable was damaged somewhere and the latch will not respond to the interior gas door release handle. As a solution, I bent the latch hook on the back of the door so that it does not securely lock when the door is closed. But, this also means the door does not fully close; the rear end of it usually stays out about 3/4 inch.
    When I pull on the handle, I hear the cable moving. So, I suspect the latch tab got separated from the cable but the cable from there to the inside handle is still functional. And so, I wonder whether the whole cable and latch button needs to be replaced or whether a repair can be done to reattach the latch tab to the cable.
    If the whole cable needs to be replaced, does anyone know to go about doing that?
    Aug 2013
    2010 Accord
    Re: gas door latch release inoperative
    Check here for the part --->OEM Honda Parts Online
    I've been seeing a lot of people on here having good experiences with them lately...
    Then grab the Haynes manual, it'll walk you through the replacement.
    The factory manual is superior to the Haynes manual by orders of magnitude and is made freely available for download (http://honda.roadpwnage.com/manuals/...-1989-full.php) by your friends here at 3geez.
    May 2012
    central Ohio
    That link isn't working for me. Are you sure it is correct?
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    Here you go
    https://www.3geez.com/forum/technical...updated-4.html
    I have an email in with the site owner. We'll see what turns up.
    LX User JohnBoy's Avatar
    Nov 2008
    87/honda lxi accord, 04 xterra, 87 f-150, 93 f-350, 75 camaro, 01 gsx-r
    spokane, WA
    mine never worked its not the cable its like the spring wasn't there so I just bent the tab and works fine.
    May 2012
    central Ohio
    Quote Originally Posted by JohnBoy View Post
    Are you saying the tab simply does not touch the door latch? In other words, you just push your gas door shut as far as it will stay shut without being held closed by the latch and you open the door by hand. Is that it?
    it was working earlier
    manual is also on the 3geez wiki as well as the electrical manual and a bunch of other stuff
    May 2012
    central Ohio
    For months, I have been simply driving without the gas cap door, i.e. with it removed. But, I don't like the look. So, yesterday, I decided to removed the spring clip on the hinge side of the door and remount the door. I have the tab (on the door) that latches to the lock cable button bent so that it barely touches the button when I close the door. And, with the spring clip removed, the door stays nearly all the way shut; it would stay in that position even if the tab was bent further and did not touch the button at all due to some stiffness in the hinge. To open the door, I can take a credit card and simply nudge the door open. This might be a permanent solution since I am hesitant to replace the whole cable.
    Nov 2008
    spokane, WA
    ya pretty much it never open tell I push on the hinged side
  1. Glove box latch
    By BoogerBurns in forum Interior & Exterior Care
    Last Post: 01-05-2011, 04:20 PM
  2. Trunk Release/Gas Release
    By canadian357 in forum 3geez Accords
    Last Post: 05-26-2010, 12:22 AM
  3. Replies: 2
    Last Post: 09-07-2004, 04:55 PM
  4. trunk latch help!
    By tynebeach in forum Performance
    Last Post: 02-03-2003, 03:49 PM
  5. Door Latch Help Needed
    By ssophab in forum Classic Honda Community Chat
    Last Post: 09-24-2002, 05:09 PM
