Installing a new vacuum advance . I am having a hard time disconnecting the plunger on old the advance from the distributor...I removed the dist cap, rotor, reluctor, igniter, stator and magnet set. I am trying to wiggle the plunger from the pin that holds it to the breaker plate but it won't come off. Any ideas on what I am doing wrong that I can't get this plunger off? It is a Hitachi distributor. ( page 24-17 shop manual )
Otherwise I will put everything back together and do some more research... didn't think it was going to be this much of a pain...
OK so after looking at the diagram, it looks like the pin ( from the top looks like a rivet ) that hold the plunger rod has a spring washer preventing the arm to slide off the pin...not quite sure how to remove it and put it back on. Maybe remove the breaker plate?
update: Ok done for the night, put everything back together and will look into this on the weekend. In the meantime if you have any tips suggestions please let me know. Thanks in advance.
