Doing some costing here to see what you guys would prefer for the rear adjusters. The product including new ball joints, allowing for +0 to -6 degrees of safe negative camber. (can be adjusted to -8) What material should I build them from? I also want to note that you will never have to buy another stock ball joint. You can simply replace the rod end ($20 a side) when they start to wear. I know you can get them from Moog, for less than what I am offering, but they don't have nearly the same about of adjustabilitly. Plus when one goes sour, you have to replace the entire thing. My part is designed to use Energy bushings, and Standard Rod ends, which means they could last a lifetime. All parts would have TIG welded flanged joints.
More Photos
